Archive through August 14, 2006
Username: Tjmutlow
Post Number: 2639
1995 Jeep Grand Cherokee Stereo Information
Constant 12V+ Red/White
Switched 12V+ Red/Gray
Ground Black
Illumination Blue/Red
Dimmer Orange
Antenna Trigger Green/Red
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Green
Left Front (-) Brown/Red
Right Front (+) Purple/Yellow
Right Front (-) Blue
Rear Speakers 6 1/2" Rear Doors
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Blue/White
Right Rear (-) Blue/Pink
• Alarm Information • Cruise Information
Username: Tjmutlow
Post Number: 2640
could not see 02 trooper, try 00
2000 Isuzu Trooper Stereo Information
Switched 12V+ Orange/Yellow
Ground Black/Yellow
Illumination n/a
Dimmer n/a
Antenna Trigger Brown/Red
Antenna Right Front
Left Front (+) White
Left Front (-) Red/White
Right Front (+) Gray/White
Right Front (-) Green/White
Rear Speakers 5" Rear Pillars
Left Rear (+) Yellow
Left Rear (-) Blue/Yellow
Right Rear (+) Orange
Right Rear (-) Orange/Black
Username: Tjmutlow
Post Number: 2641
1989-90 Ford Ranger Stereo Information
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Chassis
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Rear Speakers 5" x 7" Rear Wall
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Username: Austinguy
recently the instrument panel cluster some what failed in my 97 pontiac grand am SE (2.4 4-Cyl). all the lights work, including odometer, but none of the gauges.
i took the cluster apart, cleaned it up, checked the connections, no go.
is there anything else i should do to make it work? what about the neutral wire under the hood? can someone suggest me how and where to check ground wires? please email me at nitinchawla001@gmail.com
thanks
Username: Weetodid09
Can I get a wiring diagram for a 1996 Grand Cherokee Jeep? Thanks.
Username: Tjmutlow
Post Number: 2644
1996 Jeep Grand Cherokee Stereo Information
Ground Black
Dimmer Orange
Front Speakers 5 1/4" Doors
Rear Speakers 5 1/4" Rear Doors
Username: Ilovemydogs
Burlington, Ontario Canada
Hi!!!!
How about 2005 Ford Escape (Radio code 8) Thanks!
Username: Ramanj
Hello, Ty
I just got a new stereo I would like to install in a 1998 Ford Mustang Coupe, would you happen to have the wiring diagram or color code for the wires? Much thanks in advance!
Username: Ramanj
Also, forgot to ask but it's been awhile since I've done one of these. I am supposed to disconnect the negative wire to the car battery, correct?
Thanks!
Username: Adahir
I need the stereo wiring info on a pontiac grand AM 91' Please help.
Thanks
Username: Adahir
Actualy can you make that the wiring for the whole car because i dont know what goes where
thanks
Username: Maelthra
Can you give me a heads up on which wire does what on a '94 cavalier's radio plug? Thanks.
Username: Crnnrc2003
Hey I'm wiring a Cd player from my old car into a grand am - the wired for the Cd player has a blue/white wire and its the only blue/white wire comming from the unit- im pretty sure its supposed to be the "power antenna" wire but im also told that a blue/white wire is designed for the amp. My unit has a seperate thick black wire which im sure is for the antenna - i want to know if i should go ahead and hook up the blue/white wire to the blue one on my wiring harness... please respond
Username: Wolfman1981
Ontario Canada
hello i need help with wire color info for my 1998 Chevrolet Cavalier thanks
Username: Jjkessel
I NEED HELP! PLEASE. I'm going nuts. I have a 94 Suburban K2500 6.5L T-Diesel. I am trying to install some radio equipment. I purchased the chilton DIY manual, to no avail. I CAN NOT find the wiring diagram for the radio to save my life. Please, I would really appreciate it. Thank you in advance.
Username: Krylon
Does anyone have a wiring diagram for a 92 Mercury Tracer??? I'm trying to put a aftermarket deck in and am having a bit of trouble. Thanks!
Username: Jean57
BradfordUnited kindom
help I have a radio cassette in my ford fiesta I have got a new cd which I want to put in the wires on the block of my old one are RED BROWN YELLOW YELLOW/GREY THIN BROWN THICK BROWN.the wire on the cd are RED BLACK and 2ORANGE which goes to which and what about the two other wires my fiesta is 1997 I whould be gratfull if any one could help thanks
Username: Civic_rider
will a 93 honda civic wiring work on a 88 honda civic
Username: Jeknotts
need wiring dia for 95 ford explorer the one already posted does not match what I have
Username: Zippen
Reno, Nevada USA
i need a 1992 ford bronco eddie bauer editon wire diagram please. none of the ones ive found never matched.
Username: Jucox
Does anyone have the wiring diagram for a 1995 Isuzu Rodeo??? I've checked numerous forumns and archives but have only been able to find diagrams for 1999 and 2000, which don't match 1995.
Thanks
Username: Shaman_mikey
Yes i hooked up my cd player to my 1997 cavalier but the wires werent coverd and i heard a pop....I checked my fuses and the radio blew but i changed it and the cd player still won't work......I know the cd player works cuz we tried it on my buddies vehicle in which he has the same cd player as i do......Did i short out the wires or what could of happened
Username: Tcox_16
i have an infinity amp stock in my 2003 durango...so how do i hook my new amp up...do i have to have a remote turn on wire...and can i hook wires up to the speakers instead of using rca's because my stock stereo dont' have any rca jacks...and i dont' want to buy a line out converter...but my main problem is the remote turn on wire...how do i hook it up...or do i even need it?
Username: Illuminator
Post Number: 3679
It is absolutely necessary to buy a line out converter if you are planning to use your amp with your stock unit. There's no other way to do it.
You need the remote wire to turn on the amp...otherwise it won't turn on. Just wire it to a fuse in the fusebox that only gets power when the car is on.
To put it into common sense: Why would car manufacturers make it possible to hook up external amplifiers with no external accessories? Especially after they've spent millions themselves on developing the head unit speakers etc.
And please respond to your original post, not put another post in this thread. This one has enough :-)
Username: Steve_o_2534
Belle, Wv Usa
I have a 95 ford explorer and i am tryin to hook a system up....i couldnt find a wiring harness to fit my wires in my dash so i had to splice the wires....now i dont know which wires go to what and i cant find the codes anywhere....all of the ones posted recently dont work.....my explorer is an edie bower addition and has a "premium wiring system"...please help
Username: Mskelli22
Lumberton, Tx USA
Need help wiring a 1998 Isuzu Rodeo CD Player. I need to know what the following wire colors are:
Orange/White
Orange/Blue
Orange
Gray
White
Blue
Yellow
Green
Green/Red
Red/White
Red/Green
Red/Yellow
Red
Black
Username: Sidecutter
Help! I need to identify the wiring on my 2000 Ford Econoline 150 and the Haynes manual doesn't match the actual wiring for this stereo. The wiring I found on here for the 2000 Explorer is very close, but doesn;t cover 2-4 wires I have. My unit has the six speaker audio (I suspect the middle pair shares with either front or back for wiring to the head unit), and the CD/cassette/AM/FM head unit.
Trying to hook up a sub, and need to know so I can connect the convertor that will give me RCA jacks.
Also need to know where to hook up the remote wire.
Username: Trapdoorwpg
Calgary, Alberta Canada
I'm doing an after market stereo install on a 2006 Dodge Dakota and I was wondering if anyone would know or have the wire color codes, including the polarity of each. Greatly appreciated if you have this info, thanks a Million ! :-)
Username: Jerome
Post Number: 60
Anyone got it for a Maxima 1997 w/ bose...
Username: Miniminard123
Kamloops, BC Canada
Hey people i have a 93 ford ranger and i need to know what the color wiring diagram is.. Im installing a JVC deck and i need to know what the color is for the constent, the acc, and groundif you could hepl me out that would be great...
Username: Rcrawford
Australia
Hey Guys.
My Missus has a 1991 Fold Laser and I'm trying to get bonus points by putting in a new head unit for her, just wondering if anybody had the wiring diagram. Not sure if they released the Laser in the US though because all the US ford sites have no record of ever having released a Laser. If nobody has the wiring colours, where would i be able to find them?
Cheers
Username: Hankscorpio
1996 Ford Explorer XLT. My wiring doesnt seem to match any ive found..
Heres how mine go, can someone help with the diagram??
Green/Purple
Black
Yellow/Black
Blue/Red
N/A
Black/Green
N/A
Blue
any help would be awesome
Thanks,
TJ
Username: E250
any one have the wire color codes for a 2005 E250 radio only. any help would be great
Thanks
Username: Leew
Ketchikan, ALASKA
Post Number: 421
Username: Leew
Ketchikan, ALASKA
Post Number: 424
For TJ :FORD EXPLORER XLT 1996
the pic.above for 2005 E250
Username: Leew
Ketchikan, ALASKA
Post Number: 425
For Rob,1991 Ford Laser almost the same ford escort 1991.
first for base radio, second for premium radio(with amp)
first first first first:
second,second second second:
Username: Radiohelp
Can someone help? Need a stereo wiring diagram/color codes for 86 Westfalia. Thanks.
Username: Secrane
Wow! How in the world do you come up with these?
I would love to have the radio wiring information for the 07 Ford Explorer Sport Trac.
My guess is it is most like the 06 Explorer Sport.
Thanks
Username: Tlavery
Hello I need to see if someone could possibly provide me a schematic of the fuse panel for an 1989 ford ranger 4cyl. Thanks a MILLION!!
Username: Mac_daddy1
Here's one I can't find: 1985 Ford LTD Brougham radio wire color codes. Is this too old? Thanks in advance.
Username: Leew
Ketchikan, ALASKA USA
Post Number: 455
application/x-zip-compressedUpload
1985 Ford LTD Brougham.zip (71.8 k)
Username: Leew
Post Number: 457
Shelby Crane
what radio you got(base or premium)?
Username: Secrane
Base.
I would like to put in a nav unit but I'm not sure where the brake, reverse, and pulse generator wires are.
Thanks.
was wondering if anyone would know or have the wire color codes, which I dont think anyone has yet but would be appreciated if you have this
Username: Leew
Post Number: 464
Shelby Crane , I got some for you, it 2006, but you can try..
ford 06 1.zip (64.5 k)
ford 06 2.zip (44.6 k)
Username: Secrane
Thanks Mike.
I will try to apply this info when my nav comes in next week.
I'll let the group know what I find.
OMG, Mike Lee, you like... NAILED that one! Thanks a bunch! I feel like a pirate that just found the treasure chest. You da MAN!
Username: Leew
Post Number: 472
no problem! mac daddy
Username: Summitboy
hey there i have an 89 thunderbird lx with the factory jbl audio system and a factory jbl sub. i need to know what wires are what on all three of the plugs in the dash so i can hook up my aftermarket head-unit. one plug is a six pin square plug, one is an eight pin square plug, and one is the flat gray plug. if anyone could help me out that would be great.
alex johnson
Username: Leew
Post Number: 477
89 thunderbird lx with the factory jbl system.
89 thunderbird lx with the factory jbl.zip (40.8 k)
Mike,
Your diagram worked perfectly. Radio is up and running! I especially liked how you included the alternate premium sound packages, just in case! Very professional. Thanks again!
mac daddy
Username: Lgalaz24
I wan't to change my stock radio on a 1997 Mustang Gt... Can anyone out there please tell me what the wiring diagram is on my 1997 mustang Gt...
Username: Leew
Post Number: 484
for ford mus.gt 97
ford mustang gt 97.zip (98.8 k)
Username: Lgalaz24
Thanks!!!! I appreciate the help on my radio, I was able to set it up with a new aftermarket radio with the info....
Username: N2birds
I am needing help wiring my 99 ford contour i believe all the wires are connected correctly but all i hear is static in the speakers that still adjust with the volume. Can I please have some input? Thanks
Username: Leew
Post Number: 489
No problem,any time.
If you wanna get the navigation system,I can help you with it too (wiring set up)!
Goodluck!
Username: Cazper
any1 got wiring colors or diagram for 2005 sunfire? has the cd player deck (not monsoon headunit) ive tried using 2000 - 2004 colors and some of them just dont match up.. (ignition and a few others) i ended up blowing a fuse and putting the factory unit back in so dog doesent chew the wires when he in the car
Username: Leew
Post Number: 492
I got.
ponti sunfr2005 1.zip (38.2 k)
ponti sunfr 2005 2.zip (81.3 k)
Username: Xxmasakraxx
Help me with wiring for a 1992 toyota corolla
Username: Cazper
anyone kno ignition wire color on the 05 sunfire? i cant find it on those diagrams.. also theres a purple wire from factory radio leftover, so could that be it?.. i tried using it but it appears the new deck isnt receiving any power
Username: Leew
Post Number: 498
there is no ignition wire (memory wire)on the 05-07 Ponti Sunfire. Take it straight line from sig.lighter.(ACC Wire)
purple wire from factory radio going straight to body computer, this the MEMORY LINE,but without 12V.
By the new tech, memory from couple of units (radio,clock,sat,seats..etg.)stays inside BCM
Username: Wsr
I need Help! Does anyone know the wiring for a 1989 Mitsi lancer???? Would be much appeciated as all im waiting on is the headunit....
Username: Wsr
Okay ive sussed all tha speaker wires out but theres 5 wires left over they are:
2x bule with white spripe
2x white with green stripe
and one green with white stripe
the green one i believe is illumination however my headunit doesnt hav and illumination wire.
Ive tryed the other wires but nothing. there seems 2 be no power wires im lost.......
Username: Secrane
Hey Mike.
I'm still having trouble finding the speed sense wire for the 07 sport trac. Can you post 06 or 05 F150 radio wiring diagram. Maybe they are the same. (I know the speed sense wire is in the radio wiring harness somewhere)
Thanks.
Username: Mitchel272
Helo i have a 3 door vauxhall corsa, 1993 k reg.
but it has not wiring system at all for a stereo, beleive me i looked everywere..
my friend said its possible to buy a lead which will connect from the battery to the stereo to power it, but i cant find this lead anywhere.
any ideas, because i really need a stereo help is appreciated..
thanks
Username: Leew
Post Number: 499
Shelby Crane.
Well,look at this diagrams and try pin #14.This is VSS wire (speed sensor),he is coming straight from [engine controls system].Both head units(base and premium used the same pin #14 GRY/BLK wire).
the wire color is GRY/BLK
let me know if you cannot find it.
f150 2005-06 vss wire.zip (43.0 k)
Username: Dj_sms
I need the wiring code for a 1996 ford laser asap as i need to have it done this arvo it would help a million thanx in advance to anyone who can help
Username: Secrane
Mike,
I figured it out, FINALLY. Thanks a million for your help. It was the Purple/Orange wire on pin 1 on the PCM.
Without your help I would have never figured it out. Thanks.
I will post all the wires for everyone else...
Username: Leew
Post Number: 500
Thanks Shelby.
and
Good luck!
Username: Dj_sms
regarding the ford laser i know the speakers wires are i am left with 4 other wired blu/blk, red/blk, blu/red, red/ylw. I know red/blk is the battery and blu/blk apears to be the ingnition however the head unit won't turn on unless the headlights are on what am i missing? the other two wires appear to be the headlight and key warning sounds, help would be greatly appriciated
Username: Justinp21
Wyoming United States
I need the wiring info for a 1988 ford taurus, can anybody help??
Username: Leew
Post Number: 501
this is for Taurus GL 1988
ford taur.zip (38.8 k)
Username: Leew
Post Number: 502
@ justin,if it does not fit for you,then give me more info about your car!
your car can be ,Taurus MT5 or LX or L...!
Username: Hueso007
2003 Isuzu Rodeo Audio Wiring guide. Can someone please give me a guide as to what colors are for what in my audio? I remember back in the days the ground and live wires were thicker then the others but that has now changed.
Please help.
Thank you.
Username: Leew
Post Number: 503
Aaron,this is for you:
isuzu rodeo 2003 w.o amp radio.zip (47.6 k)
isuzu rodeo 2003 with amp radio.zip (59.6 k)
Username: Hueso007
Thank you Mike. That was fast. You take care and have a great weekend.
I'll remember you if I ever have any other questions with my stereo (if any problems occur).
Again, your help is greatly appreciated.
Username: Leew
Post Number: 504
No problem Aaron, any time!
Username: Justinp21
I cant get this to work i tried hooking up the red wire marked battery and the yellow wire marked acc (on my after market cd player)to the ones from the car, i thought if i did that my cd player would be on? im lost
Username: Leew
Post Number: 505
justin,check all the fuses! and make sure you connected right your new HU.(small advise.do it with meter)
acc wire--- YEL/BLK
batt.wire(plus all the time)----LT GRN/YEL
ground wire------BLK
Username: Hueso007
Mike, I have another one (actually two) for you good buddy. Can you please help one last time today?
My good friend gave me two Sony Face Off CD units but with out the diagrams. I know which ones are the ground and power but I'm confused with the rest.
Can you please tell me which colors are for what? Or you can send me a diagram.
Sony CDX-4180
Sony CDX 4250
Let me add one more. My factory unit is having trouble with gaining clear radio frequency...do you think maybe the unit it self is bad or should I change the antenna? I did do a thorough inspection of the antenna cable and the unit. I did not see any damage or cuts in the cable. Is there any other problem it might be? Should I just change the unit? Or should I just take it to an audio specialist?
Thanks again for all your prompt attention and help and have a pleasent weekend.
Aaron
Username: Leew
Post Number: 506
Ok Aaron,I cannot post it for sony here,file is to big,so go here:http://72.14.203.104/search?q=cache:kU5PLmd93SMJ:fileshare.eshop.bg/index.php%3F what%3Dsearch2%26searchstring%3DCDX-4180+diagrams+Sony+CDX-4180&hl=en&ct=clnk&cd =1
and about radio: it's could be a million reason,HU(head unit) no good,or cable,or chip inside the HU,or bad ground,or antenna amp. is broken....etc. Just buy in Walmart cheap antenna($ 9-15) with cable(motorola plug) and try to connect with it.If it's the same, then the problem is HU.
That is all.
let me know,if you have some problem!
and
Good luck!
Username: Leew
Post Number: 507
Aaron!!!
find exactly this row:
Username: Svttouruofl
Does anyone have the color codes for a 1992 Ford Mustang LX? A previous owner decided do to some custom wiring for no apparent reason. I am trying to run a Sony CDX-F5500. I bought the connecter but still no sound and a "failure" message due to the previous wiring. Thanks.
Zack
Username: Leew
Post Number: 510
well Zack,I got it for you.Just find, vwich one is right for your car.
ford mustang lx radio.zip (69.4 k)
Username: Mdsonic
Need Speaker wiring for 2000 Ford Contour, I have all power done but the little "L" shaped original plug was snipped and not i can't figure out the speakers.....
Username: Justinp21
hey Mike thanks for your help, it was just what i needed thanks
Justin
Mike Lee....Thank you so much for the info. This will allow me to be able to finish the installation. I immediately recognized the problem.
Thank You
Zack
Username: Leew
Post Number: 511
no problem,any time !
Username: Leew
Post Number: 512
and this one for Mike Dolsen :
contour2000radio.zip (56.6 k)
Username: M8ball
Aurora, IL USA
Need wiring diagram for 2000 ford explorer.
Username: Mark_phelps
North Carolina
1999 Dodge Durango with 6 speaker Infinity sound system. Someone has hacked the factory wires and replaced the speakers, but I think they are out of phase. Can I please get a wiring diagram?
Username: Leew
Post Number: 513
for Mark Phelps:
2000.2001 dodge durando.zip (76.3 k)
Username: Leew
Post Number: 514
Mark,dodge durango radio wiring from 1998 till 2001,the same!
Username: Spg
Can I get stereo wiring info for a 2005 F250.
Username: Sam_sauer
I need a wiring diagram for a 1996 Ford Explorer with the premium system.
Also i was wondering if this vehicle had an amplifier in it becaus i heard a humming inside the center cousel but i dont know what it is.
Thanks for all the help.
Username: Leew
Post Number: 515
Sam,If you got premium radio system, it's radio with amp and this amp located :rear right q.
ford explo.1996 radio.zip (74.2 k)
Username: Sam_sauer
Wait so my car does or doesnt have an amp and if it does where at?
Username: Leew
Post Number: 516
Yes,you car got OEM Amp.
If you open rear gate the Amp.stays on right rear quarter,behind trim panel.
