To: Muddy Waters
Username: Jenifer_contreras
Tampa, Florida USA
Post Number: 102
Hello.
This is my big problem:
My digital capacitor(it the second one), don't want to charge,when I tryed, it's come up to 4.8-5.1 V only, then stops.Once I left it to charge overnight but it's the same, 5V.
I used resistor in line, between plus (+) leads.Without this resistor(I try to connected straight{after i used resistor}),I got big spark on the batt.terminal (-) side.
So, what can be wrong? if you have some ideas,please help me out!
The capacitor is 1.5 Far.
and the car what Im trying to upgrade is Nis.Maxima 2006. Amp is Audiobahn A6601. The sub is alpine 12" single coil E-type.All speakers around is "Alpine, component".
Thanks in advance Upload
Username: Safe_cracker
Chicago, IL US
Post Number: 1305
Sorry, I am not muddy but maybe I can help? First of all get yourself a DMM (digital multi-meter) and measure the voltage at the resister to verify the voltage reading on your caps display. How did you wire it? Did you follow the directions for installation? The power should go inline of you amps power wire and as close to the amp as possible. Now the caps ground SHOULD NOT be inline with the amplifiers ground connection but to a chassis ground and as short short as possible, closest to your mounting position. Here is a link for a .pdf installation guide, maybe a different cap but you will get the idea... Polo..
http://www.stingerelectronics.com/tech_department/supercaps_manual.pdf
Username: Carguy
Post Number: 5623
Jeniffer, nice picture! Just kidding.
To charge a cap like yours (1.5F), find a 12v light bulb. Connect one end of the wire from the bulb to the pos on the cap, the other end to pos on the battery. Neg to neg.
The bulb will light up for 3 - 5 seconds then it will go out. Once that happens, the cap is FULLY charged. Now if you connect the cap directly to the power, there will be no more sparks.
I've tried using the resistor to charge the cap, it really didn't work for me.
Tampa, Florida USA
Post Number: 105
Thank you Polo.
First of all, the groud was inline with the amplifiers.(but I connected by Schoshi diagram!)
And second,the meter on my capacitor is lied.
Thanks Polo,I owe you a beer.
Tampa, Florida USA
Post Number: 106
Thank's Isaac.
and light bulb I have to use like "barrel" type, it can be any Amp.
Chicago, IL US
Post Number: 1310
Bulbs are rated by voltage/ wattage or even Lumens. Just use a 12v bulb like from your interior light, should work fine.Polo..
Tampa, Florida USA
Post Number: 108
Thanks again Polo,
I meaned Amp=watt (sorry, it my bad)
I used light bulb from dome light.It's worked.
Thank you guy's
Username: Basshead86
Google is your Friend, FL
Post Number: 4343
looks like i am too little, to late. lol
i thought it was somebody calling me out again. HAHAHA :-)
Chicago, IL US
Post Number: 1319
DOME LIGHT BULB, LMFAO....:-O
Tampa, Florida USA
Post Number: 109
wha wha,this the right name from alldata crash book.
Username: Carguy
Post Number: 5627
Muddy you snoose you lose.
Jeniffer, you're pretty handy. Now what happened to your dancing picture?
Tampa, Florida USA
Post Number: 110
Thanks Isaac.
I got today haircut!
Username: Wordscount
Well friends I am new to this forum... and must say M happy to be a pert of this community great information... thankz guys...
Username: Adddisorder
West palm, Florida
Post Number: 550
if you like this fourm you should go to " j designs . info " everything inthe "" without the spaces. its alot nicer. you should try it out
Username: Extrmndor3
Chicago, Ill Us
Post Number: 1721
hey jennifer hola como estas???? hey tienes msn??? eres una de las unicas mujeres ke se meten a estos forums???? hey jennifer u got a pic???
Chicago, Ill Us
Post Number: 1724
instead of the resistor use a test light close to the cap that will charge the cap better but slower
