3 Alpine Type-R's
Username: Bdizz54
Post Number: 13
What would be the best amp for running 3 12 Inch Alpine Type-R's they are rated at 500 watts RMS?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8555
vc configs???
Username: Bdizz54
Post Number: 15
I am just starting to learn about everything so please inform me please.
Username: Ctmike
Ct.
Post Number: 1309
are they dual 2 or 4ohm?
Username: Bdizz54
Post Number: 16
Oops there 4ohm.
Username: Naledge503
Portland, Oregon U.S.
Post Number: 115
Whoever knows. now i'm curious, what ohm load would you wire that. the12volt says at a 2.666 load or a 6 ohm load. so would you wire it to a 2 ohm load???
Post Number: 8561
budget
Username: Stnorris
IA US
Post Number: 1143
no you would wire it to a 2.666 load.
get an amp that can do like 1800rms @ 2 ohms. it might be hard to find and could be really expensive.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1791
i think he needs more power.... hehehe
