Where can i find this
Username: Firestomper25
Kenmore, Ny United states
Post Number: 13
ok well i need some mysterious cable to connect my amp to my head unit so i can control it from there. i think it is some type of s-video cable but i just dont know. I have a kenwood excelon kdc-x790 and my amp is kenwood excelon kac-x811d. i have read reveiws on this amp and they are not too good. so is this a good amp or not. i bought it for my alpine swr 1222d . and it puts out about 5oo rms. and my amp does at four ohm's about 533 rms. but yeah i was getting a little shaky and i dont now where i should wire it.. my amp that is. i would appreciate any help. thank you
Username: Illuminator
Post Number: 3925
Ebay, most likely...
Username: Makmillion
United States
Post Number: 156
E bay item number 280014715297 might work.
If you're amp has the same 13-pin connector as your head unit does then this will work for you.
BTW, The KAC-X810/811/812D amps are all great amps in my opinion. 810 was my favorite, the whole 10 hours I owned it before someone decided they deserved it more than me :\
