Alpine Type-X
Username: Bdizz54
Would the HIFONICS XX-COLOSSUS be to much power for two 12 inch Alpine Type X's Bridged at 4Ohms
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8322
specs on everything
Username: Bdizz54
Hifonics XX-Colossus 2000 Watts x 1 @ 4 Ohms Bridged
Alpine Type-X 1,000 watts RMS Each
Username: Bdizz54
Or would it just be better to just get 2 Alpine
MRD-M1005 V12 but it is only 700W x 1 @ 4 Ohms
Post Number: 8324
should be fine......also type x's are power hungry...it may not be enough power
Username: Kenwa
Post Number: 195
Another thing you could consider is wiring those subs down to 1 ohm and that would save you money on an amp im sure.
Username: Bdizz54
Post Number: 7
Won't That Put the Subs or amp in trouble.
Username: Kenwa
Post Number: 196
Only if you bought an amp that wasnt one ohm stable, but many are. If you want a hifonics amp an XX hercules is 2000w x1 at 1 ohm, and it should be cheaper than the colossus.
Los Angeles, CA USA
Post Number: 4548
orion 2500d would be perfect for those subs. you can wire them down to 1 ohm and the amp is one ohm stable.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1237
th alpines do 1000 at 2 ohms brad which is what u wire each sub to so it would work
Username: Riskyb
Post Number: 10
Personally, I have found that the RMS rating on a speaker doesn't need to be reached to make them thump.
Say you have a 1,000 watts RMS sub (accuratly rated) and you give it 800 watts RMS...
And you also have the same sub and you give it 1,000 watts RMS...
The one with more watts is going to be very slightly louder...
I would have to say its not worth spending all the extra money for a bigger amp and alternator and all that for say 3db lol..
You would be better off having say 2 subwoofers at say 60% their rated power than 1 subwoofer at its full rated power.
Username: Kenwa
Post Number: 199
Mark your wrong, that amp would work yes, but not with the subs wired the way you said. Both subs would have to be wired together is series to create a 4 ohm load for the amp to be bridged and ran at 4 ohms. But brad you would be better off wiring the subs in parallel for a 1 ohm load and buy an amp between 2000 and 2400wrms at 1 ohm.
Los Angeles, CA USA
Post Number: 4556
if you want some serious output from the type X you need to give them more that 1000wrms a piece. i know cause i used to own a pair. i had 2 jl 1000/1 going to 2 type Xs. don't get me wrong, it was loud and the sq was excellent. but i felt that it can get louder for my taste.
Username: Rzarector
Post Number: 1238
acually it wouldnt even be 3 db.. and kenny the subs are dual 4 ohm.. if hes getting 2 alpine amps each sub will be wired in parrallel down to 2 ohms on each amp
Username: Bdizz54
Post Number: 9
Thanx for all the help.
Los Angeles, CA USA
Post Number: 4605
don't get those alpine amps. i can live with subs from alpine but there amps sux.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1636
where is Andy F????????? hahahha
go with orion 2500d or with an amp in the 2000-2500w rms range at 1 ohm
