Best sql sub...
Username: Atllefty12
Pinellas, Fla.
Post Number: 174
I'm looking for the best-loudest sql sub. I'm looking currently at the RE SX, AA Havoc, S.I. Mag... All the 15" models. Any opinions and suggestions? looking to spend no more then $500 on the sub(s).
Los Angeles, CA USA
Post Number: 4557
i can say that the re sx is an excellent sql sub and it gets loud as fukkk. i tested my re sx 18 the other day with 1000wrms and it pounds. wait til i give it 1700wrms. it will be insane.
Pinellas, Fla.
Post Number: 177
have you ever heard an s.i. mag before? or the havoc? if so how would you compare them to the sx?
Los Angeles, CA USA
Post Number: 4565
no. thats why i can only give you an opinion on the re sx 18 cause i have one. i don't like to guess what certain subs sound like. i would like to own both of those subs in the future though.
Pinellas, Fla.
Post Number: 178
i should just buy all three and hook em up to seperate amps huh? lol jk
Pinellas, Fla.
Post Number: 179
chad you build mad boxes huh? how much would you charge to build me one?
Los Angeles, CA USA
Post Number: 4566
i need the following info from you.
dimensions of your trunk.
how many subs and which brand
what size box
ported or sealed
slot port or aero port
tuning freq
i don't build boxes for people cause no time but i can refer you to ATF. he builds cleaner boxes than me cause he has better skills.
Pinellas, Fla.
Post Number: 180
oh true lol. how much you pay for your sx? and where you get it from? also what amps you recommend for it?
Los Angeles, CA USA
Post Number: 4567
i got it from ebay brand new for $350 shipped. i like the price so i couldnt pass it up.
Pinellas, Fla.
Post Number: 181
def... howd u fit an 18" in your accord? lol
Username: Alex_f
Near lexington, Ky Us
Post Number: 1212
his whole back seat is a sub box.lol. Btw you mentioned the SI mag up there. Chauncey brown said they didn't get very loud, but it sounded really good.
Pinellas, Fla.
Post Number: 182
Atf, you build boxes? How much would you charge for 1 15" tuned to 33hz in a honda civic coupe... not sure of the sub yet lol. Just a price range.
Username: Alex_f
Post Number: 1213
$75+ shipping for a plain box, just carpet.
Tell me if you want anything extra on there, and i can give you a different quote.
Pinellas, Fla.
Post Number: 184
what else do you do different? you have aim?
Username: Alex_f
Post Number: 1214
yeah, AlexTF11
Pinellas, Fla.
Post Number: 185
hey chad, what amp do you have on your sx now? what amp are you upgrading to?
Los Angeles, CA USA
Post Number: 4568
i just tried it out with my jl 1000/1 and it pounds.
i just ordered a orion 2500d which will do 1700wrms at 2 ohms so i will get louder. the re sx 18 i have is a dual 1ohm sub.
Pinellas, Fla.
Post Number: 186
what if i put this http://cgi.ebay.com/HIFONICS-BXi1606D-Class-D-Mono-Amplifier-Amp-BXi-1606D_W0QQi temZ300013283032QQihZ020QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and get the dual 2 ohm sub, you think that would be too much power for daily?
Los Angeles, CA USA
Post Number: 4571
don't expect 1600wrms at 1 ohm from that amp. that amp is over rated and you will only see around 1200wrms anyways.
Pinellas, Fla.
Post Number: 188
yea thats what im thinkin lol... How far is that shop from you?
Los Angeles, CA USA
Post Number: 4572
its like 30 min drive when there isn't traffic. i went there before to watch a db drag and when i went inside the store to look around, they had re subs. i was surprised cause i thought you had to order re subs direct from the company.
here is a link to that store.
http://www.advancedcarcreations.com/products.htm
Los Angeles, CA USA
Post Number: 4573
bump damn it.
Username: James1115
Ct
Post Number: 6066
I have never heard the SI mag but personally wasnt that impressed with the SX. People who I know and trust their opinion's have heard the mag and have nothing but great things to say about it. It's pricey but nice.
Los Angeles, CA USA
Post Number: 4575
don't get me wrong. i am not going all re now. i still like treo. the re sx 18 i have now will be on sale in about a month or two. i am just using this for now cause i always wanted a 18 inch sub and the price was too good to pass up.
Pinellas, Fla.
Post Number: 189
i wanna try the sx and mag, which do you think i should do first?
Los Angeles, CA USA
Post Number: 4576
if you got the cash then go for the mag. i always value jame's opinion alot so you should listen to him. like i said before, i've never heard a mag so i couldn't comment on them. its just they are kinda pricey and i don't want to spend that much to try them out.
Username: James1115
Ct
Post Number: 6067
I have heard better thinks from about the Havoc then both of the two mentioned above. Baseball on this forum had a sx 15 then 2 re se 12's then a ava 15 and he said that his havoc destroys them all.
Pinellas, Fla.
Post Number: 190
so the havoc then? its only 450 n its 2ohm dvc
Username: James1115
Ct
Post Number: 6070
yeah I think Chad will change up the VC configuration for a extra $25 if needed.
Pinellas, Fla.
Post Number: 191
who is chad? how do i get in touch with him? Could I power it correctly with this... http://cgi.ebay.com/HIFONICS-BXI2006D-BRUTUS-2000w-MONO-CAR-AMPLIFIER-AMP_W0QQit emZ270012655648QQihZ017QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and do you think ill need a new alt. or can i just do w/ my stock one and run a new battery?
Username: James1115
Ct
Post Number: 6073
www.ascendantaudio.com Chad is the owner of the company. I don't like the low end Hifonic's amps but to answer your question would it work? I guess so but I wouldnt power a ferrari with a 1.8 liter Hugo motor would you?
Pinellas, Fla.
Post Number: 192
nice comp. lol. Any reccomendations? dont wanna spend more then $450...
Username: James1115
Ct
Post Number: 6074
thats a decent amount of money for a good amp, you could get a orion 1200d for that price. I don't have the time to search amps for you know but maybe later I will and post back. Call Chad and see what he has to say he is a cool guy.
Username: Alex_f
Post Number: 1215
Hey james, did you get my email? I sent it not too long ago....
Pinellas, Fla.
Post Number: 193
CHHHHHHHHAAAAAAADDDDDDD!!!!!! HAHA
james says ur the man until he returns...
any amp recomendations for the havoc? Dont want to spend more the $450
Pinellas, Fla.
Post Number: 194
quick ?, why doesnt everyone else have the havoc if its so great?
Username: Alex_f
Post Number: 1216
It isnt really that old. And the fact that it is like $450.
Los Angeles, CA USA
Post Number: 4580
"CHHHHHHHHAAAAAAADDDDDDD!!!!!! HAHA
any amp recomendations for the havoc? Dont want to spend more the $450"
okay he is talking about Chad Kuyper at ascendent audio. he isn't referring to me. although i am a cool guy.
