New system...
Username: Atllefty12
Pinellas, Fla.
Post Number: 173
Ok Ive been researching and losing sleep over this lol. I'm trying to look for a new sub for me to buy. I dont want to spend anymore then $500 on either 1 15" or 2 12"'s. $500 for the subs alone. A thread like this will be in the amps section after i buy the sub!!! lol The car is a honda civic coupe.
Username: 04redmach1
Columbus, GA USA
Post Number: 48
SI MAG 15
$500 shipped
www.low-hz.com
Pinellas, Fla.
Post Number: 183
will the mag have the ability to get louder then the RE SX if both given 1000-1200 rms?
Los Angeles, CA USA
Post Number: 4569
they both will get loud with that power. re fans will say the sx will destroy the mag while the mag fans will say the opposite. personally, i'd take the re sx cause of the price.
Pinellas, Fla.
Post Number: 187
do you know how much the RE SX 15" is at a shop?
Los Angeles, CA USA
Post Number: 4570
there is a shop near my house that sells re sx 12 for $299. i've never asked them how much the 15 cost though.
