Accessory needed
Username: Killswitchjd
Post Number: 280
does anyone know of a wiring accessory that combined say 3 12 guage speaker wires so it can easily be connected to a subwoofer voice coil?
I have kicker comps and the spring loaded terminal thats on there right now doesnt fit 3 12 gauge wires so well....
Username: Fandim
Reno, Nevada United State...
Post Number: 1307
Out of curiousity...? Why are you running three 12 gauge wires to one input on a subwoofer?
Post Number: 282
1 ohm, 2 kicker dual voice coil 4 ohm subs... even two does not fit well...
Username: Clouduz
Post Number: 83
one 12 guage strand should be sufficient, i don't recommend wasting the wire on one sub even if u have a lot of it. One is enough for plenty of power
