My power steering is leaking!!!
Username: Crayola0
Wisconsin
Post Number: 322
I dont know what part is leaking but does anyone know how much it would be to replace everything? i think it is just a hose i hope.
Username: Crayola0
Wisconsin
Post Number: 323
it is a dodge durango. is that normal for dodges?
Username: Crayola0
Wisconsin
Post Number: 325
i know this is the wrong section. but does anyone know anything about this stuff/
Username: Halter
Paulding, Ohio
Post Number: 171
is it your a/c leaking...like condensation from it being hott
Username: Crayola0
Wisconsin
Post Number: 326
no its my power steering cause it went out and we put fluid in and now it works and i think it is still leaking.
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 372
You can pick up a pump on ebay if thats the case otherwise if its just a bad hose or clamp your looking at a couple bucks and less than an hour or labor if you can do it yourself. That can't be fun driving a durango without power steering, i bet its fun backing out real slow without power steering. Mine ran out of fluid once and it was a pain in the as$.
Username: Crayola0
Wisconsin
Post Number: 345
it was fun...lol....i had to go a 2 days without it and it sucked. at work i couldnt even pull into a parking spot...i had to pull in as much as i could and then back up and turn the other way is much as i could then pull back in.. it was a b1tch.
