14.4 volt question
Username: Thriller73
Post Number: 10
I am new hear and see amps specrs usually have (14.4) next to the rms ratings. Others have 12. something afterwards. How do I know which one I got and if it is not 14.4, how do make it so it is?
Username: Adddisorder
West palm, Florida
Post Number: 478
its just how much voltage they take to produce their rms. some amps are rated at 12.5 (voltage of a battery) and others 14.4 (voltage your alt. puts out at full power) and MA audio rates their stuff at 17 volts...because their idiots. it doesnt really matter what you choose just pick an amp that does a little more rms then you need
Username: Illuminator
Post Number: 3624
Most amps will put out the same amount of power whether the specs are rated at 12V or 14.4V. They have regulated power supplies (PWM) so the voltage doesn't matter.
Username: Fandim
Reno, Nevada United State...
Post Number: 1306
^^ I wouldnt say most amps. Not by far.
Username: Dustin3
Tigard, OR U.S.
Post Number: 2833
yea, only a select few. PG, jl etc
Username: Stnorris
IA US
Post Number: 1072
bassman, i dont think thats what hes talking about
