What 2 10" subs should i get
Username: Vtchevy
Post Number: 8
which is the best in a sealed box, loud but good sound quality
RE sx
jl w6v2
diamond d9
eclipse ti
kicker L7
kicker cvx
alpine type-r
i can spend about $200-$300 per sub
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 576
do they have 2 be 10s? can you fit 12s in your truck?
Post Number: 577
id get this better then most subs listed, excellent sq and great spl.....http://www.ascendantaudio.com/arsenal10specs.html
and it will save you money....
Username: Vtchevy
Post Number: 9
could fit 12s as long as the the mounting depth is less than 7.5 inches
Post Number: 579
you will love thoes arsenals....
Post Number: 580
http://www.ascendantaudio.com/arsenal12specs.html
Username: Vtchevy
Post Number: 11
what amp should i get to power the 2 12s
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8260
crystal compx.....better then any sub on that list
Post Number: 582
why do you always do that, lol
Post Number: 583
whats your budget for the amp
Username: Vtchevy
Post Number: 12
$400 for the amp
Username: Vtchevy
Post Number: 13
someone told me he uses the jl 1000/1 and it sounds awesome. but those are a little expensive
Username: Sb2012
Marshalltown, Iowa United states
how bout a hifonics bx1606 would be just right and you would save about $150...1600 watts rms actually puts out around 1440 to 1560...as long as the subs are dvc 4 ohm or svc 2 ohm...u would want to run a 1 ohm load...
http://cgi.ebay.com/HIFONICS-BXi1606D-1600W-MONOBLOCK-Class-D-Amp-NEW-06_W0QQite mZ140013279497QQihZ004QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Number: 584
yea, thad work^^^ since the arsenals are dvc 4ohm....
Post Number: 585
http://www.low-hz.com/commerce/catalog/product_info.php?cPath=22_31&products_id= 54
theres a guy called showrides on here, he owns that site, he could prolly hook you up with that amp for a cheaper price...
Username: Alpineduder
So u can jack up my sy..., Hell no C-a-n-a-d-a
Post Number: 52
two 12" type-r's in a ported box would destroy that truck, trust me i got three 12's in my 2002 f-150 and its f***in loud, you wont be upset
Post Number: 586
get 2 12 arsenals.....
Username: Sb2012
yeah man...you will love them
Username: Vtchevy
Post Number: 14
how's this
2 12" arsenals in a sealed box
with this amp 1500 @ 1ohm
or would this amp be better
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=218
Username: Cjohnson
Gilman, Iowa
Post Number: 11
id go with the hifonics but u want the 2006 model..the hifonics BXi1606D...that model wont put out but 82% to 88% of its rms...
this one would be more what you would want...
