ALT for Mercedes E-class
Username: Night_mirage
AmmanJordan
Post Number: 348
Hi guys ,
yesterday i saw a red light on my Mercedes screen and its for ALT ,
Its Lighting With Bass and if i turn my all lights .
SO i need new one , But the Problem is i don't know what do i have . i mean like 200 amp HO one .
I asked for new one and its 120$ . Standerd for My Benz .
So is it better to buy HO one or what ?
I checked @ e-bay i didn't find mine .
MY system is 800 RMS amplifier . But maybe i'll upgrade so soon .
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1556
get the biggest alt you can, 200A will be more than enough but get the biggest one you can.
See if after all you can sell your mercedes alt to a mechanic and get some $$ back hehehe
AmmanJordan
Post Number: 349
does all HO ALT fits my benz or there is some brands .
Thanks
Username: Robman0079
Post Number: 110
http://www.excessiveamperage.com/
this guy gives out very nice alternators and you can even get all the necessary wiring good luck!!!
Username: Juliob
Post Number: 1583
robbie, he's not from US, maybe you should check the prices in your country, and then you call nate.
The shipping would be too high
