Honda CR-V
Username: Aman2005
Post Number: 255
Hey Guyz, my dad Has promised me to buy a Honda CR-V for me at the end of next month. Let me know can the alternator of the CR-V handle the Two Type Rs?? As I will be shifting the whole system from my sedan to CR-V. Kindly Suggest.
Los Angeles, CA USA
Post Number: 4493
which amp are you using to power your Rs?
Username: Aman2005
Post Number: 256
Thats Hifonics 1605D
Username: Adddisorder
West palm, Florida
Post Number: 529
its is hard to say. how much rms does that amp actually do. im not sure on the size of the crvs alt. but the only real way to find out if it can take the load or not is hook it up.
wickedcases.com look at the part about charging systems
Username: Aman2005
Post Number: 257
Well, Actually I've ordered an alternator for my sedan. I dont want to buy a new for CR-V, if someone can, kindly get some info abt the alt.
Los Angeles, CA USA
Post Number: 4498
who did you order from? usually if you just got the alt and you changed your car they will take it back and rebuild it for you.
West palm, Florida
Post Number: 532
^^that would be your best bet beacuse youll probly need one
