Type r or t1
Username: Hockeyknight
Post Number: 157
whats louder a 1 12" rockford t1 or 1 12" alpine type r
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1443
i'd pick type r. Depends on the install....
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1316
T1s can get pretty loud. they dont sound very good in my opinion, but they should get louder than a type R in the right box.
Post Number: 160
how much louder and in what box?? i dont really care about sq. oh ya and i have an old type r soo that will make a diff if ur thinkin that i have the new ones... thanks fer the help
Username: Dloc
WHITTIER, CA USA
Post Number: 33
for the ti i would recommend a ported box.....
Post Number: 161
would it be a lot louder than 1 12" odl type r
Username: Juliob
Post Number: 1449
damn i thought it was a p1, t1 should be louder, get a ported box and tune it to 40HZ and you'll be happy
Post Number: 163
Pioneer TS-W3004SPL how would this compaire to a t1 or a type r????
Username: Juliob
Post Number: 1460
man what's your problem with alpine haha, what do you want, that pioneer is SPL only, alpine is SQ, that's it!
Post Number: 164
i dont have anything against alpine but i own a type r and a v-12 amp and im wondering whats louder cuz i dont really care about sound quality
St. Louis, MO
Post Number: 1319
treo TSx 12
Mmats P2.5 12
both subs can get very loud in the right boxes. i would tune the box to around 38-42hz and ull be set.
Post Number: 166
whats the rms on those cuz i dont really wanna buy a new amp... i got an alpine v12 that says its pushing 600 rms
St. Louis, MO
Post Number: 1320
you can keep that amp as long as you get dual 4ohm subs. 600 watts is plenty to get those moving.
Post Number: 168
dual 4 if im only getting 1 12"? hey thanks fer the help just 2 more q's... where can i buy 1 and wich do u recomend for only ONLY sPl? thanks
