4 alpine type x 12'' 6000wrms at 2ohm?
Username: Johnfiac
Il USA
Post Number: 322
http://www.alpine-usa.com/en/products/product.php?model=SWX-1242D
Just to make sure before i check all my space available to build the custom box to fit this and still have room for my batterys and amps and all..... 4 of these ran at 2ohms would be at 6000wrms right? are these subs underrated also? i am going to have 2 amps strapped togethor to, they claim 6000wrms at 2ohm but are also underrated.. 6000wrms at 2ohm?
Username: Rovin
Trinidad & T...
Post Number: 8674
never used those X but i would say do NOT give them 1500wrms each !
they r SQ subs so i would be afraid 2 power them 1.5 times like other brands like treo/dd ........
Username: Alias747
MN
Post Number: 1150
I don't think that you will have too much of a problem, just keep the sub output on the head unit set a little lower. A shop near me hooked a Kicker 2500.1 to a 12" Type X and it took it fine. And that kicker is rated at 2900+ wrms!
