Username: Crayola0
Wisconsin
Post Number: 306
What is a good setup for around $400-$450. Im looking for more SPL 12's or 15's. Doesnt matter how many subs. And an amp to power them. i will be building a box. and have plenty of room for a bigger box.
Username: Crayola0
Wisconsin
Post Number: 307
are these subs any good?
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13993
Username: Crayola0
Wisconsin
Post Number: 308
if not how bout these.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16703
Username: Killerzracing
Fredericksburg, Virginia United states
honestly i heard a set of those crunch subs 4 12's in a 10-11cuft box ported it hit 152 on Audiocontrol..... so thats not saying anything good or bad...... beacuse its all in the design he had a good box but they were holdin up on a Powerbass 3000 so i guess those Cruch subs would work there cheap an u want spl go for it.....
if i could make the pic i have smaller i would upload that box that guy had
Username: Crayola0
Wisconsin
Post Number: 309
what is a good budget amp for these.
Username: Rovin
Trinidad & T...
Post Number: 8679
3 of these ported http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14520
& 1 of this
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16368
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1442
kicker 15 l7 and the amp rovin posted
Username: Crayola0
Wisconsin
Post Number: 310
dude that would be too expensive.
Username: Crayola0
Wisconsin
Post Number: 311
are dayton subs nay good?
Username: Crayola0
Wisconsin
Post Number: 312
anyone?
Username: Loudon
Post Number: 440
those square hifonics subs .. as quoted by some people on team maxxsonics ... as "L7 killers"
and dayton woofers are good driver ... wont be dissapointed with them
Username: Crayola0
Wisconsin
Post Number: 314
what about for budget. 400-450 for sub(s) and amp.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 372
Take a glance at this:
sub: http://www.sonicelectronix.com/item_5169.html
amp: http://www.sonicelectronix.com/item_6522.html
http://www.sonicelectronix.com/item_3092.html (im sure its overrated but should work fine)
http://www.sonicelectronix.com/item_3732.html
or this:
sub: http://www.sonicelectronix.com/item_6492.html
amp: http://www.sonicelectronix.com/item_3732.html
or maybe this?:
sub: 2 of these: http://www.sonicelectronix.com/item_4281.html
http://www.sonicelectronix.com/item_5403.html
http://www.sonicelectronix.com/item_6517.html
ok getting tired now...
Username: Crayola0
Wisconsin
Post Number: 315
is there anything wrong with running a sub off of eaceh channel on a 2 channel amp?
Username: Crayola0
Wisconsin
Post Number: 317
anyone?
Username: Ctmike
Ct.
Post Number: 1185
nothing wrong with using a 2 channel for subs.
Username: Crayola0
Wisconsin
Post Number: 319
cause some ppl tell me to bridge it. but y when i can run 1 off of each channel.
Username: Killerzracing71
Post Number: 1087
the only reason they say people use mono amps is beacause not many Multi channel amps produce enough power for Subwoofers...
if the power doesnt change from when u run the subs seperate (at its lowest Impedence) then when u bridge it it doesnt matter
like the MRV-545
250x2 @ 2ohms
500x1 @ 4 ohms
depends on ur componets an ur plans for the system
with a 2 channel u can run ur music in stereo so it can have a left/right sub (like if music changes or if u watch movies thorugh a DVD player it will have the effect of movement
(correct me if im wrong)
thats all
o Travis Johnson is me dont know y it changed...
but 152dbs is quiet loud wonder whut that is on term lab
Username: Crayola0
Wisconsin
Post Number: 320
o well i dont think im gunna be watching movies in my car.lol.
