Pioneer DEH-P9800BT What yall think?
Username: Tiggerboi87
Pensacola, FL United States
Post Number: 98
Does anyone here own this HU. What do yall think about it? Also whats difference between this one and the Pioneer Premier DEH-P980BT
one?
Username: Illuminator
Post Number: 3527
It's a good head unit, I don't own it personally, but it has some good features.
The difference between the Premier and regular Pioneers is always a common question...
-Premier label in place of the Pioneer label.
-Higher pre-out voltage
-Longer warranty
-Sometimes the premier has gold-plated RCA pre-outs.
-The build quality seems to be better to endure the longer warranty.
Not a massive difference, but definitely worth it.
Username: Lucky_man
The pioneer site states that the only differences are :
1) Auto EQ , Auto TA (Time Alignment)
2) 2 year warranty
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8205
I have heard that the 900series are the same as the 800's but the screen gets stuck....
Post Number: 3593
Mario, true, but that's only for a few Pioneer units. I was doing the general differences.
Username: Lucky_man
Jexx, I mistakenly thought you were referring to the P980BT.
I'm going to be buying one soon, but I'm disappointed that the premiere doesn't have higher voltage. 5 volts is still pretty good.
The differences between premiere and non-premiere are becoming less significant. I wonder if its even worth it for Pioneer to keep making two versions.
Post Number: 3598
Yeah, even I don't know why they make regular and Premier versions. I think the biggest reason to get a Premier is just the build quality-they just seem to be built better-maybe it's just me, though.
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1633
"Premier label in place of the Pioneer label. "
Why is that a better feature lol?
Post Number: 3606
It's just a difference, not necessarily a feature unless you wanted to show off to your friends you spent the extra forty or whatever difference it costs. haha
Username: Alteraudiousa
Concord
Post Number: 1091
the warranty on a premier unit is 2yrs instead of 1, the EQ makes a BIG difference, the preouts helps, and the TA is nice to have. Its a killer unit especially when using the bluetooth part which is pretty fun. Easy to use and a nice OEL screen too.
