Dimensions for the a8000t
Username: Homercleeze
Post Number: 14
ive looked at a few different places and seen different results. anyone with expierence know exactly how big one of these are? i have limited space to mount the amp next to my converter so i might have to go with a different amp for my treo. thanks in advance
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 446
you can almost mount an amp anywhere...
Post Number: 15
its not for a car dude, i have limited space to mount an amp. can anyone please give the correct dimensions?
Username: Basshead86
Google is your Friend, FL
Post Number: 3987
11-5/16"W x 2-5/8"H x 13-1/4"D
Post Number: 449
wow mine are different..Dimensions: 1-7/8" H x 9-7/8" W x 11-7/8" D
Post Number: 17
THANK YOU, muddy. *sigh* the amp is too big, does anyone have a suggestion other than the brutus for a compact amp to power a treo tsx 10" dual 4 ohm?
Post Number: 3989
Height: 1.88 in
Depth: 11.88 in
Width: 9.88 in
i can't find any that are the same either. lol
your best bet would be to email A-bahn's tech dept. and they will tell you.
these amps put out closer to 600wRMS, incase you were unaware.:-)
Post Number: 18
"wow mine are different..Dimensions: 1-7/8" H x 9-7/8" W x 11-7/8" D"
now that would fit. i cant go over 10 inches in one direction due to the height of my radio.......where did each of you get those figures from?
Post Number: 453
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=106
Username: Dustin3
Tigard, OR U.S.
Post Number: 2617
the a8000t's muddy?? they put out 810 watts
Post Number: 19
heres another thing thats gotten me confused, ive seen the a8000V and the a8000T out there. the "V" is the bigger one, is there a difference? or is the 8000T an older model or something?
Post Number: 3991
the a8000t is a class a/b amp.
it has 2 30 amp fuses...which is closer to 600wRMS than it will EVER be to 810. lol but w/e
i am not sure about the V
i got one from bizrate and one form sonicelectronix
Username: Naledge503
Portland, Oregon U.S.
Post Number: 47
yeah the a8000t is last years and the a8000v is this years.
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 259
What about the DUB4001 it says its a 800 watt class a/b mono amp..and less expensive than the a8000t. what is the difference?
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1558
"these amps put out closer to 600wRMS, incase you were unaware.:-)"
Isaac has tested that line of amplifiers...All put out the power listed. Of course, not being JL Audio /series, the voltage plays the important factor.
Post Number: 3997
there in lies the problem....not everybody's charging system runs at 14.4V:-) lol
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 1060
chit i know mine doesnt.....13.7 is the highest iv seen an i looked yesterday.....its 11.8 off it was 13.2 before that battery is dead......
Post Number: 4012
mine runs at like 15V:-O:-O:-O:-O:-O
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1300
14.2 - 14.8v for me...:-) and i have a crappy battery
