Alpine type x
Username: Sunnyice
Post Number: 19
what do you guys think about this subs? are they in the same level of w7? people say it has sq and can get really loud.. havent heard it my self though.. 1000 rms for a 12' sub is pretty good i think.
Username: Ctmike
Ct.
Post Number: 1095
no, it is a decent sq sub but is definatly not worth the price. the w7 is alot better.
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1293
it depends where your buying them from and what you expect out of them. they dont have very much SPL, but can sound very good in a small sealed box. theres some on ebay for around $200, not a bad SQ sub at all for the price in my opinion.
i had 2 12s before and they sounded good but didnt have enough SPL for me.
for the record ive heard just as many W7s sound bad as ive heard sound good. im not a fan of them.
Los Angeles, CA USA
Post Number: 4365
if you like sq i would say get the type X. the w7 will get louder but sq wise it ain't much better. the type x plays a wide range of freq well. it blends well with the rest of the sound in your car.
