Silver Member Username: Extremesound1Coventry, RI United states Post Number: 195 Registered: Mar-06 | If u were to buy any sub off amazon under $350 for SPL, what would u buy ..... only off amazon my sister is getting it for me im under 18 so i cant buy anything off the internet |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3982 Registered: Aug-05 | kicker L7 |
Gold Member Username: Cenus420 , 420 420 Post Number: 2016 Registered: Jan-05 | kicker cvx |
Silver Member Username: Extremesound1Coventry, RI United states Post Number: 196 Registered: Mar-06 | i want something a little different than those everyone has them at my school.. how about 2 cvr 15in |
Bronze Member Username: MakmillionUnited States Post Number: 79 Registered: Apr-06 | earthquake DBXi-15D http://www.amazon.com/gp/product/B000GYD4GC Never had a problem with earthquake and they're pretty rare in most areas.. |
Silver Member Username: Extremesound1Coventry, RI United states Post Number: 197 Registered: Mar-06 | do they have good sound quality too. and i want EXCURSION!!!!!!! so over 2 15in cvr and 2 earthquake 15IN which is better or if there is another choice |
Bronze Member Username: MakmillionUnited States Post Number: 80 Registered: Apr-06 | DBXi-15D * 750 Watts RMS 1000 Watts Peak Power * 15" cast frame subwoofer * Single or Dual voice coil 4-ohm / 2-ohm * XMax 1.5-Inch, 30.48 mm * 3" voice coil, aluminum bobin * Sensitivity 88 dB * Free Air Resonance 20Hz * 160 Oz double stacked magnet Can't find specs on the CVR 15 that state the xmax, and I can't find the manuals to mine so I couldn't tell ya.. but the earthquake will live up to its name. |
Silver Member Username: StnorrisEldridge, IA US Post Number: 877 Registered: Apr-06 | if ur looking for excursion, a cvr is not the right sub to be lookin at. the 15 cvr, has less excursion than the 12. i think the 15 only has .490, and the 12 has .498. also kicker cvrs dont have very good of sq. |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2634 Registered: Oct-05 | hes only lookin for spl though. i would get some cvx's, over all the suggestions listed. |
Silver Member Username: Extremesound1Coventry, RI United states Post Number: 198 Registered: Mar-06 | cvx it is, i dont know to much about the earhtquake. they have 2 12in cvx on ebay but not 15in,, does it matter or will 2 12in sound as good |
