What is a good audiobahn setup ??
Username: Night_mirage
AmmanJordan
Post Number: 310
Please do n't say audiobahn sucks .
i found finally some stores near our country witch are selling some nice products like audiobahn , i know you will say get kicker or hifonics but i can n't there is nothing in jordan like these companies .
i found audiobahn in lebanon , United Arab Emarate , Bahrin .
SO i'll travel to one of these and buy an amplifier and sub's
what do u think is the best @ the worst company as you all say's .
i want 1200 - 1800 RMS amplifier .
and three 12" sub's . in ported box .
what do u think , My budget is 800$
Username: Kaerfpl
Spencerport, NY USA
Post Number: 229
For usuing 1200-1800 RMS, your probably gonna need to upgrade your alt. Also, how come you have to get it at a store? There's always ebay and other on-line store where you can get things cheaper.
Username: Rovin
Trinidad & T...
Post Number: 8496
if audiobahn is so common then surely u can get PIONEER/PREMIER subs cause anywhere u go u can get these & they r lower price & still sound pretty good
look @ pioneer 306 subs or u can get a single 12" premier 3002 model 1000wrms each & still use abahn amps if u want.......
AmmanJordan
Post Number: 312
thanks Rovin . and Joe
okay Rovin there is 306 pioneer but primier we do n't have .
and 306 is so week .
what is a good bahn amplifiers ??
and sir i'm out of US .
Username: Rovin
Trinidad & T...
Post Number: 8505
u find 306 r weak !? 4 ur tastes really !?
maybe u havent heard 1 or some install properly - 4 the $ it gets plenty loud
they r also the cheapest "best bang 4 $ sub" i can rec , get 4 & come back & thank me -lol
abahn amps i never used that blingy stuff - since ur choice is so limited i suggest u get 1 that more power than u need since every1 seems 2 say they r underpowered ....
Username: Adddisorder
West palm, Florida
Post Number: 429
for audiobahn amps only buy out of the intake series the ones that end in "t" seem to be pretty good budget amps
AmmanJordan
Post Number: 313
Rovin is that 306 you ment which 400 RMS .
this one :
Pioneer TS-W306C 12"
• 1000W Max • 4 Ohm • • 400W RMS •
____________________
is it SVC ?
thanks . i'll buy 4 if u mean this
AmmanJordan
Post Number: 314
about amplifiers :
intake means these ::
A12005DN
A8005DN
A16000V
but what about this ?
A1300HCT
Username: Rovin
Trinidad & T...
Post Number: 8506
YES ! ^^ then also come in 4 ohms dvc model as well , i had 2 of them ported & it got pretty loud
recnt car show here a guy had 12 of their 10" models in a wall & it sounded damn good !..
consult this
http://www.the12volt.com/caraudio/woofer_configurations.asp
so u know which amp to sub coil config 2 get ...
AmmanJordan
Post Number: 315
okay but what is the diff between these DVC and SVC .
Which better ?
we just have single voice coil .
is it good ?
Ya i 'll buy 2 ohm apm . if its DVC .
if its single i'll buy 1ohm ,,
Username: Rovin
Trinidad & T...
Post Number: 8509
no difference performance between either version - they just choices so in case if some has a 1ohm or 2ohm stable amp so do check ur amp 1st
heard quite a few 306 4 12s installs just last wk end - they r enough loud 4 most owners of st driven cars .....
AmmanJordan
Post Number: 316
Thanks Rovin .
I found these amplifiers and sub's
what do u think ?
is it any good ?
ALUM12N 1000RMS DVC 6 ohm
AW1205N 1000RMS DVC 2 ohm
and
A8001DT
A12005DN
thanks .
Username: Dustin3
Tigard, OR U.S.
Post Number: 2531
get the A16000V, It would be better than any higher up audiobahn amp. 1600 rms @ 2 ohms
AmmanJordan
Post Number: 317
okay but what about sub's .
what is the best from audiobahn .
Username: Dustin3
Tigard, OR U.S.
Post Number: 2539
i thought you were goin wit pioneer 306's?
AmmanJordan
Post Number: 318
pioneer 306 is better than these sub's ??
thanks
Username: Dustin3
Tigard, OR U.S.
Post Number: 2563
i would take pioneer over audiobahn subs
Username: Cadillacdb
Houston , TX
Post Number: 730
Night mirage,,, Audiobahn amps are fine and they all hit there rated power no matter which line they are from as long as they arent the Dub stuff... but the subwoofers arent good so i would go with three pioneer 12's over the three Audiobahns and then get a Audiobahn Amp that can supply them with enough power depending upon the ohms load that u will have the subs wired for
AmmanJordan
Post Number: 319
thanks all , Now i found a1600V , A800T , A1200 .
what should i buy ?
its soo expensive but i have to pay , I don't have choice ..
