Port placment
Username: Bretzy1990
Springfield, Il U.S.
Post Number: 90
does it make a difference if you place the circle port in the rear of the box and the subwoofer on the front or do u have to place the port on the top or side of the box.
Post Number: 91
i dont have enough room to put it on the front of my box and if i put it on the sides it would be like half an inch away from the walls of the trunk. if i put the port on the top id say its even less than half an inch to the top of the trunk. this is why i would like to know if putting it in the rear of the box would have any drawbacks to the subs performance.
Post Number: 94
BUMP.... lol im putin my ports in tomorrow
Username: Rovin
Trinidad & T...
Post Number: 8493
usually best when on same side as woofer
but it appears like u so DID NOT plan ur box design/available space properly .......
Username: Troy81
Tavernier, Fl Us
Post Number: 625
it doesnt really matter, personal preferance mostly, itll sound different, not quieter
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 1028
any more input cuz i wanna know to.... i plan on porting my box that i have 2 theres no room to put the port upfront at all so it will have to go on the side
Username: J_baby15
Kentucky
Post Number: 449
i'd go with on the side.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 360
I wouldn't do the side. Most places say 4" from the nearest solid object. If your box is against the seat I would say wherever but like rovin said, you should have planned.
Username: J_baby15
Kentucky
Post Number: 454
idk...ive heard sum side sum side ports that sound good.
Post Number: 1030
i have room around my box because i moving it on my rear end "HUMP" look at any old car u will Know whut im talkin bout
anyway im building a false wall around it so if i have 4" of clearance it should b fine
