1200 wrms amp for cheap...
Username: Killswitchjd
Post Number: 235
im looking for a 1200x1 wrms (around there) amp at either 1 ohm or 4 ohms (1 ohm is probably easier to get in my price range).
the amp is for two kicker dual 4 ohm cvr's
budget is about as cheap as possible while avoiding brands like lanzar or audiobahn
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 451
look for a kicker kx1200.1 or orion 1200D on ebay. good quality for a low price.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2196
are they 12"?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1205
bassman, what happened with Hifonics 1206d
Username: Dustin3
Tigard, Or U.S.
Post Number: 2211
lol. i didnt recc. an amp yet :-( ^^^ you could go wit that amp
Username: Tjmutlow
Post Number: 2587
you can run a 2 channel and run it series/parallal on a 4 ohm load....
Username: Dustin3
Tigard, Or U.S.
Post Number: 2224
PG 1200, memphis 1100
Username: Johnfiac
Il USA
Post Number: 271
http://cgi.ebay.com/1500-Watt-Amp-CrossFire-Distinct-Audio-Amplifier-D1500_W0QQi temZ130004498810QQihZ003QQcategoryZ18797QQrdZ1QQcmdZViewItem
not sure if its good but its cheap only 170$ish plus 30 day warranty...
Username: Afroopuff
Post Number: 146
edesignaudio.com the NINE.1 amplifier, 350 shipped
Username: Nissankicker
Grambling, LA USA
Post Number: 95
Get a JBL BP Series 1200.1
It's 1200 rms @ 1 ohm
Actually, w/ the right power supply
( With 14.4v , .. the birth sheets says 1400 @ 1 ohm )
