Best affordable amp for two 12" alpine type-X's ?
Username: Anthony469
please recommend the best amplifier for two 12 inch alpine type-X's. i have heard about buying and amp that it stable at 1 ohm and this being the most cost efficient amp. please leave all manufacturers and models that u thinkj would do the job.thanx
Username: Dustin3
Tigard, Or U.S.
Post Number: 2358
cant you do some research??
is it dual voice coil 4 ohm, 2 ohm... wuts the rms?
Username: Rovin
Trinidad & T...
Post Number: 8480
current model of type X ONLY come in 4ohms dvc & is 1000wrms each
loof for an amp that does @ least 2000wrms @ 1 ohm
Hifonics bxo2006 is prolly the most affordable amp 4 it
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16370
Username: Dustin3
Tigard, Or U.S.
Post Number: 2364
^^ thats prolly the best bet. IMO, i really dont like the X's very much. they are alright, but def my great
Username: Dustin3
Tigard, Or U.S.
Post Number: 2365
^^ that would be ur best bet. IMO, i really dont like the X's ver much. they're alright
