Assassins
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 207
Just wondering, but did the prices go up on the Ascendant Audio Assassins? I thought the 10's were $55 last time I looked and now they are $70 each. So I need 2 and it looks like $167.05 shipped. OH and what Kicker amp would be good for them?
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 328
does it have to be kicker?
Post Number: 209
WELL, no, not really, but I remember asking which amp to use with the assasins and they recommended a kicker for a good, inexpensive setup...just cant remember which one.
Post Number: 330
whats the rms on the assasins?
Post Number: 210
well, it says they recommend 200 watts, but the RMS is 350.
Post Number: 331
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=279
Post Number: 333
are they dvc or svc?
Post Number: 211
svc. and OUCH that amp is too expensive...looking for something in the $100-$150 range
Post Number: 336
uh...you could try an audiobahn a8000t...
Username: Gangstafert
Jacksonville, Florida USA
Post Number: 265
that audiobahn would work fine those subs can take more than their rms says anyways so that should be a good amp.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1246
audiobahn rocks, well at least that amp... jejeje
Username: Jdog123
Vestavia Hills, Al United States
Post Number: 14
if your looking for a cheap and good amp try checking out the profile line of amps. i have the 2000 watt model and it works nicely and makes my audiobahns sound........well pretty good for audiobahns. i like the profiles a lot. very very good prices for a great amp.
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2730
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=235
Username: Iufan4lifeul
Post Number: 1119
Phoenix Gold 600rms amp. $170
Alpine- 400rms. $120
Kicker 400.1. Rated at 450rms. $130
Username: Stnorris
Eldridge, IA US
Post Number: 542
ill agree with juliob...the a8000t continues to ROCK. for the price, what an AMP.
Username: Emdawg12345
Post Number: 56
this should help
Post Number: 213
f u c k o f f tommy k
Post Number: 215
I'll probably go with the audiobahn, has the most rms for the lowest price, thanks everyone....except that IDIOT Tommy K.
Post Number: 216
one last thing, right now I have 2 SVC Alphasonic Q-Reference series subs (200 watts max) powered by a Visonik 350watt (220rms x1 @2ohms) mono amp. I can hit in the high 120's and sometimes as high as 132db. How much louder will things be with the 2 10 inch assasins and the audiobahn amp if I put the subs in the same box I already have? OH yeah, and the box is not ported.
Post Number: 217
OOPS one more thing, how powerful an amp do you have to have before you need a HO alt?
Post Number: 218
>BUMP<-
Username: Ctmike
Ct.
Post Number: 1038
how big is your alt. now, and how much power you running? personally, i wouldn't go over 900w, maybe a little more, but if your lights start dimming and such, best get one.
why not just buy one now though? you a member on the new site? if so there's a group buy going on.
Username: Troy81
Tavernier, Fl Us
Post Number: 535
never again say that juliob
Post Number: 219
yo ctmike,read above, you will see what I am looking at going up to. I still have the stock alt. but will only be going up to 800 watt amp. also can anyone tell me what I should realistically be able to hit db wise with the assasins and the audiobum amp abov?
Post Number: 220
bump
Greensburgh, PA US
Post Number: 55
Don't have one, but the price is fair. Plz don't blaze me for this guys.......www.audio-warehouse.com/web/mdl/V317SX/detail.asp
Post Number: 224
NOPE, audiobahn is cheaper
