New to Subs, need help on 500$ System
Username: Tweek52
Post Number: 49
Hi, i know little to nothin about subs and im looking to put preferabbly two 12''s or 15''s into my honda accord. I was wondering what is a good setup to get some thumping bass that sounds good. Thanks
tweek
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 1012
there are so manu options to pick from.........
tell us this
preference of music
can u build an enclousure or would u buy 1
and whut stuff were u looking at
nothing cheap is good and nothing good is cheap.....
but i have my system in my car for 500-600 from crutchfeild
Mb Quart raa-1000 (1000 true continous watts)
2 Mb quart Pwe 354 15" subs
the subs are not made to get loud but do a decnet job.....
the amp is the most important thing...... getting a reliable amp that produces the rated power not like sonys 1200 watt amp that only makes 300 contionuis
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1345
its like ordering food from a menu
u want the steak(subs)-
wut well done(12") meduim(15") or rare(18")?
so wut side u want, the salad(amp), the soup(alt) or both(amp and alt)???
wut would u like to drink, water(cheap battery) or soda(yellow top)?
and wut we all hate
HERES YOUR BILL!!!!!
Username: Rovin
Trinidad & T...
Post Number: 8445
nice anology ^^^ - lol
bottom line - it comes down to $$$$$ , post a budget ....
Username: Nm31
What year is your honda accord because i have also have a 04 accord i want to put a system into.
I would like to get a JL Audio system (w7's)
and its gonna be around $1,300
sounds like you need a lil more cash
Username: Swisher
Marianna, FL
Post Number: 214
what all do you need just subs and amp? or subs amp components? or subs amp components deck? what do you need?
