Need to get best system possible for 250
Username: Dualshotty
i am spending 250 dollars what is best system i can buy i dont need something that will break windows jus wanna add some more bass to my stock system
Username: Dandandan
Brisbane, Queensland Australia
Post Number: 154
2 alpine type rs in ported box n a cheap amp ummm lests say kenwood amp do u need a cd playa and speakers as well?
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 530
if i were you i would save up a little more than that.... 2 type r's would cost him at least 170$ for 10's and 200$ for 12's which would be leaving him strapped for the amp, wires, and box
i would go with a pair of kicker comp c12's (basic but not the worst ever invented
item 190005701892 on ebay (ebay liks dont like to work) so just type it in thea search feild
these r 8 ohm single coils so you can parallel them for a 4 ohm load
and although not the best in the world but keeping it in your price range would be a Power acousik ts620-2 pushing a claimed 360 watts @4 ohms bridged (it prolly really only puts out about 280-300) i think it will do just fine.
ebay 110005567088
this system would be in no wa super hard or even hard at all really but will ad you some decent sounding bass.
Username: Ironslave
Post Number: 531
on the up side of a low power system is that you can go to wall mart nd buy the cheepest wiring kit for like 15$ :-) and ittle do just fine until your ready to upgrade another step :-)
than all you need to do is go buy some box building stuff from home depot or wherever and build u a box... (or you can just be lazy and buy some build your own boxes from walmart... but even this would put you just outside your spending range.
Post Number: 33
thanks i have looked at the kicker comp series do they beat the p1 and mtx4500 and wut about running this pioneer amp http://www.bestbuy.com/site/olspage.jsp?skuId=7675991&type=product&productCatego ryId=cat03087&id=1134702499156 i dont need anything that will rattle my bones jus some decent sounding bass
Post Number: 35
i got a good cd playa and got spekaers jus need amp and sub i think im goin with one 12 inch sub to conserve space i have a lil ford ranger ext cab would this amp be better so i dont over do the subs which take a 150 rms http://www.circuitcity.com/ssm/Sony-2-Channel-Xplod-Amplifier-XM2002GTR-/sem/rps m/oid/144142/catOid/-13644/rpem/ccd/productDetail.do
Username: Emdawg12345
Post Number: 68
this should help http://www.rotteneggs.com/?refid=182315
Username: Fatkid
Post Number: 10
get this setup its all matched for the best results
http://cgi.ebay.com/FUSION-FEW-12PK-CAR-SUB-BOX-AMP-PACKAGE-POWER-ENCLOSURE_W0QQ itemZ120005749425QQihZ002QQcategoryZ32822QQcmdZViewItem
