13W6 or 12W7
Username: Caraudio
Toronto, Ontario Canada
Post Number: 497
If you had the choice which would you go for with the 500/1 RMS JL Amp??
Username: Rovin
Trinidad & T...
Post Number: 8417
u would be not powering the 12w7 up 2 its full potential so i'd pick 13w6 or maybe a 12w6 .....
Username: Caraudio
Post Number: 498
What would a 12w7 need to power it?
Username: Caraudio
Post Number: 499
Username: Sploosh56
Ohio
Post Number: 1409
JL 500/1
I'd go with the 13W6
Username: Caraudio
Post Number: 501
would you say 1000-1 amp with a 13W6 and have the gain to about 75% this way im not pushing the amp to its max? Or just up the 13 Dub 6 to a 7?
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 800
if your gonna go w/ the 1000/1 i would say either the 12 or 13w7 it depends on your budget and what you want. if it were me i would go w/ the 13w7.
Username: Caraudio
Post Number: 502
12W6 or 13W6 with 500-1 so far people are 50/50
Username: Johnny619
San Diego, CA
Post Number: 173
I got a Pair of Jl 12w6v2 and it some great. i used to got a 12w7 on a jl 500/1 and it sound pretty good
