Questions about sealed boxes.
Username: 420pimp2
Post Number: 779
If i had a sealed box would it sound better if i cut a whole in the bottom or side so more spl would enter the car. Or would it sound like sh.it?
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1210
sound horrible...you cant just cut a hole, you need a port.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2155
lol. thank god you asked here first.
Username: Matt12490
Benicia, California USA
Post Number: 1082
perfect example of how your post count has nothing to do with your knowledge...
Username: Thomas_g
NM
Post Number: 1365
lol :-) ^^^^^
Username: Clouduz
Post Number: 26
ok, sry to hijack the thread, but i have a sealed also and i was thinking about getting a port, can i go to an audio place and just have them port it using my existing box? port is better than slot right? I like the sq of my sealed but want more spl too
Username: Thomas_g
NM
Post Number: 1369
Next time IcePick just make ur own thread peepz will get to u but to answer ur ? Round and slot port IMO is moreless da same, ya u could take it to a shop but just go on to a website and figure it out urself so u can save money and it depends on the volume of ur enclosure if it matches ur subs recommendations then go head and do it. Use PVC port it is way easier.
Here is a website u can use:
http://www.the12volt.com/caraudio/boxcalcs.asp
Username: Dandandan
Brisbane, Queensland Australia
Post Number: 153
were the positve and negitve things on the woofer box cant u just take that out and put a port in that hole were the wires go into the woofer box?
Username: Pelona
Perris, California USA
Post Number: 1647
i thought u would know that p1mp
Username: Rovin
Trinidad & T...
Post Number: 8413
doesnt ppl pay attention & remember stuff they read on this forum & other online sites .....
