Volts???
Username: Budy
how put a 14.0volts in my car or 17.0volts
Username: Van_man
Boston South, MA
Post Number: 725
??? 14, and racecar spelled backwards is racecar
Username: Illuminator
Post Number: 3337
jonathan, I've seen the English language marred pretty badly, but man, that's really pushing it. haha
Your car is getting 13.8-14.4V, and chances are you can't change it because the voltage regulator is inside your alt. Why would you want 17V? Some amps and headunits won't even power up with that many volts.
Simply put...don't worry about it, you're only going to mess things up lol
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1172
unless you wanna get a new HO alt
Username: Dustin3
Tigard, Or U.S.
Post Number: 2122
^^ you still wouldt get 17 volts
Username: Redliner
Wilmington, Ma
Post Number: 2128
the only time u want 17 volts is if u are into comps (which by your questio i dont think you should cause u dont know anything lol) but ya like running a dd z1 for ex they run on 17 volts to make them run cleaner but then again that is basically for comps
Username: Thomas_g
NM
Post Number: 1367
lol ^^^^^^^^^^^ lmao
Thatz tight i never new that bout racecar...lol
