Grounding Q
Username: Buckiller
Post Number: 14
I was going to run a wire from my HU to near my amp (common Ground) and was wondering if using a larger gauge wire is okay? Ive read tons of stuff about keeping the ground wire the same as the power but does it matter if larger?
Username: Carguy
Post Number: 5581
Unless your device requires high current, it'll make no difference.
If you have the money and space, use larger gauge wire.
