Like
Is directed as good as orion??
Username: Blainew
Post Number: 1329
Username: Blainew
Post Number: 1330
will directed amps get the full rated RMS
Username: Hdubb
Farmington, Nm Usa
Post Number: 2047
its basically the same amp if you are talking new orion they are both made by directed so i say they are the same. but old orion is completley different. lol.
Username: Blainew
Post Number: 1332
is that considered old orion?
Username: Hdubb
Farmington, Nm Usa
Post Number: 2050
haha no. lol. they arent bad amps whatsoever they weere just great amps in the early 90s. om talking like the hcca series. they were cheater amps. but new orion is still a pretty good brand, id use it if i could. how much power are you needing? and was there a price range?
Username: Benzino
Michigan US
Post Number: 22
I own a directed 1500d and i couldnt be happier with it...
Username: Thebufromnc
Rockwell, NC
If your going to go with a Directed Audio company amp, sell that amp u got and go to Ebay and get a Viper 1200d.1 Best amp ever made by Directed. They also make 600.1d and 2400.1d. They are mono block, but have two (-) & (+) outputs for subs. i got mine wired to two Rockford Fosgate P3 10' Dual 4's at 1 ohm and the Viper can hold this 1 ohm easily. gets the true 1200 watts to your speakers, depending on the powers source you got. Good luck.
Username: Blainew
Post Number: 1333
well theres 16 brand new directed d1200s on ebay right now for 229 with free shipping
thats an unbeatable price for 1200 real watts
so i will buy one
Username: Blainew
Post Number: 1334
sh!t i mean d2400s
Username: Benzino
Michigan US
Post Number: 23
I dont really like the new directed amps the old 1500d's rms watts is rated the same as a new 2400d...
Username: Blainew
Post Number: 1335
well....will the d2400 actualy do 1200 watts @ 1 ohm??
Username: Benzino
Michigan US
Post Number: 24
yeah
Username: Blainew
Post Number: 1337
okay and one more question
when you strap two of those... what ohms do you need to present them with?? or is there no way to know unless you read the manual
Username: Benzino
Michigan US
Post Number: 28
I'm not for sure prolly have to read the manual.
Username: Blainew
Post Number: 1338
alright thanks
Username: James1115
Ct
Post Number: 6028
I believe they put out most power strapped at a 2 ohm load.
Facebook
Shop Related Deals
Directory
