Is this bad?
Username: Dannyboyy
Peterborough, NH USA
Post Number: 167
my brother has a 2 channel amp. he has 3 subs in his car and this is what he did. he ran 1 channel to each subwoofer. then took the bridged channel.(the positive from one and the negative from the 2 channels) and ran it to the 3ed sub. it seems to me this would be bad. it sounds good and his amp works fine so i dont know. any1 suggest anything?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1925
depends on the amp if it will work, like my kx200.2 it can be done but my brothers kenwood amp won't. i think its called tri-way but im not sure.
Username: Dannyboyy
Post Number: 168
sso could i do this to my RF t5002?
Username: Cenus
Post Number: 1926
idk, do you have the manual, my kx200.2 manual in the back has a diagram of one sub being hooked up to each channel and then one sub mono.
Username: Dannyboyy
Post Number: 170
no i dont but hey ill try it if it goes into protect mode ill stop.
Username: Cenus
Post Number: 1927
LOL that works to.
Username: Dannyboyy
Post Number: 173
lol
