Can some one help me with my Pioneer?????
Username: Bobmk
Honolulu, Hawaii Usa
Hi, I just got a Pioneer Deh-P6400 and I was wondering if anyone has a connection diagram so I can find where I can plug in the speaker wires. I am not useing an amp I am just useing the built in amp in the head unit. Please help!
Username: Illuminator
Post Number: 3121
http://cgi.ebay.com/Pioneer-Wire-Harness-DEH-P6400-P730-P7400MP-FH-P4000-pm_W0QQ itemZ9740526047QQihZ008QQcategoryZ64579QQrdZ1QQcmdZViewItem
It's only $13 on ebay....do you already have that harness?
If so, http://www.bcae1.com/images/gifs/ashdclos.gif
Username: Bobmk
Ya I have that harness. Thanks for your help!
Username: Bobmk
Post Number: 8
I have another question...How do I set the time on the Deh-p6400. I can't figure it out.???? Please Help...!!!!!
Username: Dkchillin
Vermont
Post Number: 132
I had that deck back in the day but I can't remember how I set the clock. I know the owner's manual is on the pioneer web site though. Go here and search for "deh-p6400" and it should be under the documents tab on the deck's page.
Username: Bobmk
Post Number: 9
Hey thanks but it won't let me log in to view the owners manuel....is there a way that u can log in and send the manul to me????
Username: Dkchillin
Vermont
Post Number: 133
Click here to hopefully go to the manual and setting the clock is on page 32. If that doesn't work, you have to hold source until the deck turns off, then press and hold function until the menu comes up then select clock then use the directional keys to set the time.
Username: Bobmk
Post Number: 11
Hey thanks a bunch... it worked!!!
Your a life saver. Thnks!!
Username: Cogdillb
Spearman, TX United State...
Post Number: 19
I have a Pioneer DEH-P7700 and its the same.
Red: Constant 12 Volt
Orange: Constant Memory
Black: Ground
Yellow: Illumination
Blue: remote wire
Set Of Green: Right Front speaker
Set of Light purple: Left Front Speaker
Set of White: Right Rear Speaker
Set of Grey: Left Rear Speaker
Hope this helps you.
Username: Bobmk
Post Number: 12
Thanks
