Infinity subs with kenwood 1000W amp, good match?
infinityman
I have two infinity 250W RMS @ 4 ohms each (SVC). I was thinking of getting the Kenwood 8151 Class D mono amp, which pushes 400W @ 2 ohms or 200W @ 4 ohms, would this be a good combo??
if the kenwood is only 200 @ 4 ohms and ur subs added together are 500 @ 4 ohms then i think you need more power. i havnt delt to much with svc subs, so i dont know if you could wire them in 2 ohms.
infinityman
yes, you CAN wire them to 2 ohms, so I guess I would be getting 400RMS to each one?
sounds like that would be a pretty good match. I've got a friend with a kenwood amp, and let me tell u its great! has it hooked up 2 some kickers. sounds awesome.
