Rockford Hx2 or Audiobahn?
Username: Ldm497
Which sub is better, and by how much?
AUDIOBAHN AW1251T 800W RMS SUB
# 12" High Performance Subwoofer
# 45 OZ. Strontium Magnet
# 2" 4 Layer Black Aluminum Voice Coil
# 400W RMS Power Handling Per Sub
# 800W RMS Power Handling Per Pair!
# 24Hz - 1kHz Freq. Response
# 92.1dB Efficiency
# Bumped & Vented Polished T-Yoke
# Poly Coated 2 Layer Non Pressed Paper Cone
# Lug Lock Terminals
# Dual 4Ω Voice Coils Per Sub
# 1Ω or 4Ω or 2Ω Stereo Operation
# Rubber Gasket & Magnet Mesh Cover
# 5-1/4" Mounting Depth
or
Rockford Fosgate HX2 RFD2212 PUNCH Sub
# Impedance 4 ohms
# Cone Material Fiber Material
# Surround Material Santo Rubber
# Sealed Box Volume 0.8 - 4
# Ported Box Volume 1.75 - 4
# Port diameter 4"
# Port length (inches) 10.75"
# Dual Voice Coils
# Sensitivity 88dB
# Frequency Response 26 - 0.2k Hz
# RMS Power Range 150-500 watts
# Peak Power Handling 1000 watts
# Top Mount Depth 5 13/16
# Cutout Diameter or Length 10 15/16
# Vas 75
# Fs 29
# Qts 0.48
# Xmax 14
Thanks in advance :-)
Out of those choices, the Rockford Fosgate, with the money spent, something totally else. It looks like you're going for SPL, I'd save up and get an L7, or Elemental Designs, Cerwin Vega Strokers.
Username: Pat_l
Tucson, AZ USA
Post Number: 87
Its a no brainer- Rockford
Cron
Audiobahn is just terrible. Between the two you should go with Rockford. Even though Rockford isn't like it used to be.
Cron
