200A Alt. Problem....****NATE****
Username: Johnfiac
Il USA
Post Number: 167
I think my alternator is taking a crap on me.... i lose voltage, it drops down to about 11-12V when i get 3500-4000rpms and i looked at it this morning and it looked like it was wet on the inside covered in a oil or somthing, i dont have any leaks in my engine..it was clean, i think it came from the alternator somwhere....did my alternator blow? or is it going to? i still got a running car as i know of so far...i switched to my stock 100A and it works alot better...... Nate can you repair Alt. to? i am not sure if its under warranty still with where i got it.
Username: Muddy
get a new alt....
Username: Titanbk
Mansfield, CT USA
Post Number: 108
should have just bought one from nate in the first place!lol
Username: B101
Queen City, NC USA
Post Number: 3274
John, you alternator been crappin on you since you registered... but you kept saying you had a alternator..
Contact Nate, he might be able to help you..
www.excessiveamperage.com
Username: Johnfiac
Il USA
Post Number: 204
find out soon, i brought it back hes sending it to cali for a new one.... but i still need to buy one from nate soon anyways..200 isnt big enough
Username: Swisher
Marianna, FL
Post Number: 186
who did you buy it from?
Username: Excessiveamps
Dothan, Alabama Good Ol U.S....
Post Number: 102
Sorry for the late post, I have been busy with emails and work. I dont get to the forums too often when I am pretty busy. Hit me up if I can help. nathanpeddicord@yahoo.com
