Amperage Calculations
Username: Phreezerburn
In order to figure out the size of alternator I need, would this way of thinking work:
I take the values from the manuals of the amps and deck that read "Current Consumption" and add them all up and get 107 amps
How much would the rest of the electrical system in a typical car be? Say 20-40 amps?
Then would a 150 amp alternator do just fine for my needs? Right now I have a stock 105 amp Alternator in a Cavalier and the sound system isn't installed yet, still doing fiberglass work. My older system which drew about 80 amps ran with some heat issues, amp would turn off at high volumes, so I figure it was the electrical system.
--------------System Specs------------
Deck:
Premier DEH-P980BT
Amps:
Premier PRS-D4000F
Premier PRS-D5000SPL
Speakers:
Premier TS-C720PRS
Premier TS-W5000SPL
Username: Highstone
Post Number: 214
how many RMS are the amplifiers?
Premier PRS-D4000F is 300w RMS
Premier PRS-D5000SPL is 1500w RMS
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2709
150 might do...id go 180 to be safe
Username: Illuminator
Post Number: 3222
To calculate the current draw of an amplifier, multiply the number of channels by the RMS watts per channel (a 2 channel amp rated at 300 watts RMS per channel would be 600 watts). Double it to account for amplifier inefficiency (600 watts X 2 = 1200 watts), then divide by the average output Voltage of an alternator, 13.8 volts (1200 divided by 13.8 = 87 amps). Since the average music signal requires about 1/3rd of the average power in a test tone, divide by 3 (87 amps divided by 3 = 29 amps). The result is the amplifier's approximate average current draw.
Multiply the amount of current your alt puts out by 40% and that's how much current you have to play around with.
Username: N2audio
Lawrence, Ks USA
Post Number: 891
Amps running hot probably isn't an electrical system issue.
But I think A 150A alt would work nicely.
