Viper 5000 range problem
Username: Razvanro
can anywone know haw to boost the range of my viper 5000 because if I give a command my car will do but the pager doesn't receive back the signal for confirmation
Username: Ruthless06
Post Number: 87
If you give the command, like to say, remote start, and it remote starts. But your 2 way system doesn't let you know. Then it could be a few things. Either the two-way transponder system has faulted out. The remote could be bad. One of the wire in your antenna could have shorted. Or maybe the brain isn't sending a signal. I would try to get a new remote and try that first.
Username: Fadmaid
i have a big problem!
i have a viper alarm on a ford transit.
and i think so because my remote says so.
fcc id:ezsdei 474v; rpn 473v.
sometimes my alarm deactivates silenly
by ITSSEFL! and today insead of two beeps
on the deactivation it gave my like 4 or 5.
can i fix those problems?
how do i eve fiind out my alarm series?
thank you very much.
Username: Justin27
Jackson, NJ USA
i have a big problem i sent my remote through the wash so i can not deactivate my alarm i used to be able to bypass this now i cannot figure it out and i need to program a phython remote to it ....any suggestions?
email me at Jtownkid17@hotmail.com ...thanks
