Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 421 Registered: Aug-05 | why does my amp goes into safe mode when i turn it up to far? im using a streetbeat amp, untill i start making more money, it only cost me $60 and its 4 can, 600 watts, using it on my 15 inch clarion. i have it wired wrong? my sub is dual voice coil, and 2 ohm per VC. i was told i might have it wired wrong. i dont know any other info about the amp except what i told you. weather its wired wrong or not, im going to try it wires differnt ways, and im going to use thincher wire, would thicker wire improve performance? im using thick wire every where else, except to the sub. |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 422 Registered: Aug-05 | can some one give me different ways to wire it too plz? |
Gold Member Username: Young_jamesCanada Post Number: 1589 Registered: Sep-05 | sounds like your clipping it to me |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 423 Registered: Aug-05 | whats that mean? |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 424 Registered: Aug-05 | http://i45.photobucket.com/albums/f89/Astrosafari/bestway.jpg theres a pic i made, of ways to wire it, u will have to take it to paint or sumthin to make it larger, i dont know why it saves so small |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 426 Registered: Aug-05 | bump? |
Gold Member Username: Thomas_gNM Post Number: 1307 Registered: Oct-05 | Ur probably overloadin it. |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 428 Registered: Aug-05 | can you be more speacific? |
Gold Member Username: Thomas_gNM Post Number: 1309 Registered: Oct-05 | Ur overloadin ur amp. |
Gold Member Username: Thomas_gNM Post Number: 1310 Registered: Oct-05 | Improper impedence from subs to amp more than likely. |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 429 Registered: Aug-05 | how? sup to powerful? its only 600 watt rms, unless u mean the ohms? |
Gold Member Username: Thomas_gNM Post Number: 1311 Registered: Oct-05 | ja i mean ohmz..... Ohm load |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 430 Registered: Aug-05 | how do i fix it?? |
Gold Member Username: Thomas_gNM Post Number: 1312 Registered: Oct-05 | Put tha proper ohm load to ur amp... |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 431 Registered: Aug-05 | how do i find out what the ohm load is and umm how do i do that? |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 432 Registered: Aug-05 | i rewired it a differnt way, and tickend the wires, it doesnt go into safe mode any more |
Gold Member Username: Thomas_gNM Post Number: 1315 Registered: Oct-05 | Well then maybe u wired it right now. U must know the specs of ur amp and subs to wire ur subs properly........... |
