Bassman3 ....
Username: Caraudio
Toronto, Ontario Canada
Post Number: 452
Will the 13Kv.2 450RMS sub and Nine2.X 400RMS sub and amp combonation beat the AUdiobahn 800rms at 2ohms and CVX dual 4 or 2 ohm sub?? I kno the numbers out do one another but what will have a great output? Interms of more louder cleaner bass?
Username: Caraudio
Post Number: 453
I mean the 13Kv.2 is 350RMS and 125 dollars and the 13Ov.2 is 195dollars and 600WRMS Now how much better would the OV be to the KV and will it out do the kicker?? Also since there amps are supposably under rated
400x1 @ 4 ohm
150x2 @ 2 ohm
100x2 @ 4 ohm
Would somthing like that do good for the 600WRMS Sub? Beacuse its another 60 bucks for the extra 200RMS. Right now if i will spend money id look to spend it right and ill strech it just for this tho.
Username: Caraudio
Post Number: 454
Or the 11Ov.2 is also somthing id consider. I just want to know from that range either a 10 or 12" that will out do the kicker CVX.
