Help with arsenal ported box
Username: Buddyleee5
Post Number: 275
Accroding to AA's website they recommend 2.0 cuft of air space per woofer and the box tuned to 35 hz. So that would mean that i need a 4 cu. ft box tuned to 35 hz, but there lies the problem. The height on my box is restricted to 13" and i can't go any wider the 38". According to one of hte calculators i used i would need the box to be 30" deep. and that won't fit into my trunk. How can i make a ported box for these fit into my trunk?
Right now i have them in a 2.8 cu.ft sealed enclosure, but i'm planning on entering a few car shows this summer and i would like to have a nicer install.
I was also thinking of doing some fiber glass, but i have been told doing that for the first time is not an easy task. Any help and suggestions are welcome. Also if you have arsenals and they are ported how do you like them?
sorry for the long post just trying to get everything out
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2690
well all i can say is ur screwed lol.
id just go with one arsenal in a nice ported box...until u learn to fiberglass.
start by fiberglassing kickpods and get to where ur good at that.
or if u can fit 3.5 cubes...ask chad from AA if u can switch ya 2 12;s for a 15
Post Number: 276
i can't fit a 15, the highest i can fit is 13"
