Customizing my car help!
Username: Jeffless600
Post Number: 124
By the end of the summer i will have 1,000 dollars to put into my car. 01" black crown vic. I can either get some 20"s, or i can get the windows tinted, get a K&N intake, and flowmaster exhausts and maybe another sub or amp. Should i just get the rims? or get all those other lil things. or just save up more idk.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7015
work inside out
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 400
id save up more then wen u have enough throw sum 24 on it with a lift kit then ull be ballin :-O
Username: Fandim
Reno, Nevada United State...
Post Number: 988
I'd get the flowmaster, and save up for some hooker headers. completely re-do your exhaust etc.. Huge performance gains to be had there.
Forget the 24's - it's too cliche. Bigger isnt always better unless you're tryin to look tacky. 20" might look good, I almost got some for my firechicken, but opted for 18's instead, saved a couple bucks and like the look MUCH better.
Subs + Amps never hurt, either. ;)
Post Number: 405
DID U PAINT UR CAR BLACK?????
BTW NICE RIMS
Post Number: 125
im lookin for a nice clean cut look, ebay my only choice for 20's for about 1 grand?
Username: Young_james
Post Number: 1492
be sure you leave enough for rubber too. No good to spend all your 1000 on rims and not afford rubber to put on them. That can get pricey too...
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2198
yeah maybe the rims for $1000 .. but the tires are gonna be expensive too . I got my 20's and tires at a local shop for $1500
Username: Fandim
Post Number: 992
yeah.. For the tires and wheels both, I ended up paying around 1800 shipped for chrome 18's. And yes, drivingreckless, I got my car painted black with a blue pearlescent in it. Used to be white. :-)
Username: Jkidder
Spring hill, Florida Usa
Post Number: 199
invest that 1 grand n' forget about any of that crap.. u'll be glad u did believe me
