Arsenals should go in sealed or vented boxes?
Username: Stamant
Pensacola, FL USA
Post Number: 188
Is it true if you divide Fs by Qes and if that value is below 50 then the sub is made for sealed enclosures. Or if the number is above 90 then the sub is designed for vented enclosures. How true is this? What would I lose if my subs are designed for sealed and I put them into vented enclosures?
Username: Stamant
Pensacola, FL USA
Post Number: 189
Does anyone know?
Username: Ctmike
Ct.
Post Number: 845
putting them in a ported box will just make you lose sq while gaining some sql.
Username: Ctmike
Ct.
Post Number: 846
putting them in a ported box will just make you lose sq while gaining some spl.
Username: Ctmike
Ct.
Post Number: 847
ignore that first one^^
Username: Stamant
Pensacola, FL USA
Post Number: 190
Mike, but would not that be true for all subs. How much better would the arsenals sound in sealed boxes? Have you heard the equation I listed above?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7820
to answer ur first question,.yes
50 or below...would perform better sealed
51-89 sealed or ported...(most subs)
90+ ported
Username: Ctmike
Ct.
Post Number: 851
true for all subs as ported makes you lose some sq, yeah as far as i know.
don't know how much better sealed the arsenals would be though. i bought a pair but haven't put them in yet cause i've been waiting for amps for them.
Username: Gangstafert
Jacksonville, Florida USA
Post Number: 153
ctmike what amp are you gonna get i have my two arsenal 12's just sitting in the boxes cause i have no amp,its so sad :-(
Username: Ctmike
Ct.
Post Number: 852
yep, mine are sitting in my closet just waiting. i've been waiting for the nine.1 to get back in stock so i can get 2 of them.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 301
CT and/or Cutlass pic up aa AutoTek in the group buy from B
Post Number: 154
i was going to get a kicker sx1250.1 but its alot and im saving and i am curious about those autoteks will they push my subs good and if so which should i get?
Rock Vegas, NC US
Post Number: 304
I just bought a 2000.1 from B for my 2 15's. The 1400.1 would push them great and you cant beat the prices. I was saving up for 2 Kicker 750.1's for mine but when I say this deal I was all over it. Buy the amp and if you dont like it you could probably re-sell it for at least what you paid for it. The kicker would be a good amp too but you will be putting a heck of a lot more to them with the 1400.1 (assuming your electrical system is up to par).
Rock Vegas, NC US
Post Number: 307
https://www.ecoustics.com/electronics/forum/car-audio/239842.html
Username: Splmonster
Post Number: 253
i have my 15 selaed, its about 2-2.5 not really sure, i think it started at about 2.4 but i cut it down a bit lol
Username: Ctmike
Ct.
Post Number: 853
how's your arsenal sound sealed? i bought them without ever hearing them, only heard the assassin. so what do you think there comparable to?
Post Number: 255
will be able to tell ya in a couple hours, got everything but, gotta wait till mah pops comes home from work so he can connect the power to the battery, but i cant really tell ya what itd be comparible to lol all i ever heard is like, shoot lemme think, 2 12 explodes, 2 10 memphis, 2 10 off brand crap forget what they were, 2 12 duals, thats it and im sure the arsenal will be a he.ll of alot better than those lol
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2658
lol ur in for a suprise.
Rock Vegas, NC US
Post Number: 315
what do you mean by that Wreak...?
Username: Demon_pride
Crowder, Oklahoma USA
Post Number: 169
He means AA will blow those off brands away. When I got my SX's and hooked them up, the closest thing i could compare them to was my friends 12w7, and they blew it away. I had heard some RF's before that and some Volfs, and I was completely suprised. This is a great first system for you man.
Post Number: 257
lol i have it hooked up i just cant get the pwer wire to hook to the battery, any ideas? their is a rubber piece and the connecter thats supposed to go around the post on the battery wont go in because of the rubber thing around the post, their is also a metal ring, so i just dont know what to do.....
