Got my treos in today. Quick question
Username: Zepcoe
Collierville... Us
Post Number: 427
The left sub in the box is like it has no flex to it like it has a block of wood stuck in between the sub. What does that mean does it mean it it blown ?
Username: James1115
Ct
Post Number: 5946
pic's would be nice but a block of wood in your sub is never a good thing. It sounds like a frozen VC.
Username: B101
Queen City, NC USA
Post Number: 3240
were they used? sounds like you got a frozen sub! not good.. If you push around the VC the entire cone should move in then out.
Username: Van_man
Boston South, MA
Post Number: 613
probably arc welded the coil to the side. try to free it and use some thermo fluid on it.
Username: Van_man
Boston South, MA
Post Number: 614
Thermo fluid, (inside Joke)
Los Angeles, CA USA
Post Number: 4119
what do you mean by a block of wood stuck in between?
Username: Van_man
Boston South, MA
Post Number: 625
"it like it has a block of wood stuck in between the sub." IE the coil is frozen
