Diminished output from amp
Username: Algirard1
OH United States
Post Number: 192
My friend just bought two type r's and a hifonics bxi1606d. We hooked it all up and we were getting power but the speakers were barely moving. I set the gain properly but they still didn't put out like they should. I was wondering if anyone wouold have any suggestions on what to check to get the speakers bumping like they should.
Username: Illuminator
Post Number: 3214
What are the head unit settings like? Most are default to the lowest possible or middle sub volume settings.
Username: Algirard1
OH United States
Post Number: 193
He has a pioneer and the sub setting is at 0. You can adjust it higher or lower.
Username: _jay_
Post Number: 160
set most of your bass stuff all the way up...it could be because you have a bad ground?...or bad speaker wires..but u would usualy hear that...
