NEED HELP PLEASE
Username: Reef
Post Number: 343
Ok i just got done with my box and every thing and got it all hooked up and i got wire to 2ohm and when i first listen to it they pound hard as hell and then after like 5 minutes not even at half volume my amp over heats then comes back and then shuts off again after another 5 minutes and its pissed me off my amp is a A8000t and its air cooled my piece of sh*t sony never over heated like this, what is wrong?
Username: Reef
Post Number: 345
Any body
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2356
are you sure you have a 2 ohm load?? check with an ohm meter if you can.
are you using a proper gague wire for the amp?? something too small will kill the current and can cause the amp to shut down.
are your gains set way too high?? if so you are over driving the amp and clipping.
Username: Reef
Post Number: 357
ok i wired it wrong they are dual 2 ohm and there are a red and black terminal marked with a white dot to show thats one voice coil and the solid red and black is another and i didnt wire both voice coils together, its kinda hard to explain lol. im gunna hook them up and see it thats wat was wrong
