Archive through June 09, 2006
Username: Tjmutlow
Post Number: 1823
1998 Dodge Neon Stereo Information
Constant 12V+ Pink
Switched 12V+ Red/White
Ground Black
Illumination Orange
Dimmer Black/Yellow
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
• Alarm Informa
Username: Fojo65
how do you bypass a pre-exsisting amp in a 1998 ford contour? i know the color code to the speakers yet they are nowhere to be found. the wires that come out of the dash are different colors and i cant find the amp in contour either. help me if anyone has any help they can give.
thanx
Username: Timayyy
Chalmers, In Usa
i need the colors of the factory wires for a 2000 kia sophia please help. the clip was chopped off
Username: Db7873
Munday, TX
I'm looking for the wiring diagram for the radio in a 98 Eclipse
Username: Dayita
Please a Want to install a new radio in a mitsubischi montero sport nativa 1999. I want the wiring information.
Thanks
Username: Jmballar
hey ty can i get the wiring for a 96 toyota camry
Username: Tjmutlow
Post Number: 1829
Sephia Stereo Information )
2000 Kia Sephia Stereo Information
Constant 12V+ Blue/Red
Switched 12V+ Blue/Black
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Black/Yellow
Left Front (-) Blue/Orange
Right Front (+) Blue/Green
Right Front (-) Light Green
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Green/Red
Left Rear (-) Green/Black
Right Rear (+) Blue/White
Right Rear (-) Red/Blue
• Alarm Information • Cruise Information
Username: Tjmutlow
Post Number: 1830
1998 Mitsubishi Eclipse Stereo Information
Constant 12V+ Red/Black
Switched 12V+ Blue
Ground Chassis
Illumination Green/White
Dimmer Black/Yellow
Antenna Trigger White/Black
Antenna Left Rear
Front Speakers 5 1/4" Doors
Left Front (+) Black/White
Left Front (-) Black
Right Front (+) Black/White
Right Front (-) Black
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
Username: Tjmutlow
Post Number: 1831
1999 Mitsubishi Montero Sport Stereo Information
Switched 12V+ Blue
Ground Chassis
Dimmer Black/Yellow
Antenna Right Front
Front Speakers 4" Dash
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Username: Tjmutlow
Post Number: 1832
1995-96 Toyota Camry Stereo Information
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Trigger Black/Red
Antenna Driver's Pillar
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Light Green
Right Front (-) Blue
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
Username: Db7873
Munday, TX
Thanks Tymutlow, your a life saver. On the 98 Eclipse, what do the illumination, and dimmer hook up to?
Username: Tjmutlow
Post Number: 1836
ther should be a wire on the aftermarket radio for those wires, sometimes just the ill wire.
Username: Perfectedsounds
i have a 95 mustang i was wondering why the assorise for the cd player the red wire is not getting power to it i checked all the fuses and the relays none are bad dose any one happen to know what could help?
Username: Tjmutlow
Post Number: 1841
there has to be a bad fuse somewhere, under hood, and some cars have 3 fuseboxes.
Username: Tjmutlow
Post Number: 1842
and that s/b the yellow/blk
Username: 91civic
i need the colors of the wires for the stereo on a 1991 honda civic hatchback
Username: 91civic
i need the wiring diagram for a 1991 honda civic asap
Username: Tjmutlow
Post Number: 1858
1988-91 Honda Civic Stereo Information
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Dimmer n/a
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Username: Samctay4
DETROIT, MI US
wire color codes for a 96 ford thunderbird
Username: Petbeg
1994 Mercury Sable wiring diagram? please?
Username: Tjmutlow
Post Number: 1876
1995-97 Ford Thunderbird Stereo Information
Constant 12V+ Black/Orange
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination Light Green
Dimmer n/a
Amplifier Remote Dark Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 5" x 7" Side Panels
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
Username: Tjmutlow
Post Number: 1877
1994 Mercury Sable Stereo Information
Constant 12V+ Green/Yellow
Illumination Light Blue/Red
Dimmer n/a
Antenna Trigger Orange/Blue
Antenna Right Front
Rear Speakers 5" x 7" Rear Deck
Left Rear (+) Pink/Light Green
Left Rear (-) Dark Blue/Orange
Right Rear (+) Pink/Light Blue
Right Rear (-) Tan/White
Username: Barwelle
ty mutlow, looks like you're a great person for helping all these people out. Thankyou from all of us for helping us out.
Now, I too have a wiring dilemma. I have a 1986 toyota camry. None of the color codes that I can find correspond completely with all the colors that I have. I'll give you a list of the colors and if you could help me, that'd be great.
yellow - battery/memory
red - ignition/accessory
black - ground
white - ??
blue + yellow stripe + brown spots - ??
(one of the last two is for antenna power, but i dont know which one or what the fifth color is for)
light green - front right spkr +
blue - front right spkr -
pink - front left spkr +
purple - front left spkr -
pink + blue stripe + red spots - ??
brown + black spots - ??
grey + red spots - ??
blue + red spots - ??
As I said, only some of the colors are on the color codes that I have found, but for the ones with the ?? beside them, I cannot find any answers for. Thanks for your help.
Username: Jrom
I need the stereo wiring color code for a 1996 VW Jetta Trek. Thanks in advance jrom.
Username: Alexwi
Sydney, NSW Australia
I need the factory head unit wiring color code for 1999 Toyota Echo. Can anyone help please?
I need to connect it to the plugs provided by Pioneer 5850.
Username: Big_ben_96
i need a stereo wiring for a 1996 ford contour i have it hooked up but i have no memory.
Username: Makmillion
United States
Post Number: 51
I need a million dollars, a bigger big screen tv, bigger subs and a ferrari.. please help!
Username: Mcelwaney
I'm looking for the wiring diagram for the radio in a 93 ford escort. Please help.
Username: Hmaymes
I'm looking for the stereo wiring diagram for a 2001 Ford Ranger... Stock CD is giving alot of problems, please help so I can install an aftermarket CD Player.
* Ty Mutlow KICKS AZZ !!!
Username: Amberk
Navarre, FL Us
what about a 97 Ford Ranger i see the 91-92 ford but is it the same??? help
Username: Reyeswd
Hatfeild, PA USA
How do i install a JVC stereo into a 1991 Ford Escort LX. The wires in the ford escort are different form the Jvc can someone PLZ help ME PLZ. reyeswd@comcast.net
Username: Reyeswd
Hatfeild, PA USA
Username: Drizzo
Post Number: 18
have a 2000 blazer wit stock cd player, bought rca line output converter but i dont kno how to connect it cuz i dont kno which wirezz r for tha speakerz i need help.wha colors mean wha.
Username: Ash7503
I'm trying to install a new Sony radio. Does anyone have the OEM wiring diagram for a 91 Mitsubishi Gallant. Pls email ash7503@yahoo.com.au THANX
Username: Srpskielvis
North royalton, Ohio Usa
Does anybody know what wires to connect to what wires to get the speakersto work on a 1991 Ford Thunderbird?
Username: Tjmutlow
Post Number: 1933
1989-91 Ford Thunderbird Stereo Information
Illumination Blue/Red
Dimmer n/a
Antenna Right Front
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Username: Tjmutlow
Post Number: 1934
1991-93 Ford Escort Stereo Information
Ground Red
Dimmer n/a
Antenna Trigger n/a
Front Speakers 5 3/4" Doors
Left Front (-) Blue/Light Green
Right Front (-) Green/Yellow
Rear Speakers 4" Side Shelves
Username: Tjmutlow
Post Number: 1935
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|yellow |+ |ignition harness |
| STARTER|red/lt. blue |+ |ignition harness |
| IGNITION|lt. green/purple |+ |ignition harness |
| ACCESSORY|gray/yellow |+ |ignition harness |
| SECOND ACCESSORY|black/lt. green |+ |ignition harness |
| POWER LOCK|pink/yellow |- |driver door harness or PKP |
| POWER UNLOCK|pink/lt. green *4 |- |driver door harness or PKP |
| LOCK MOTOR|pink/black | |driver door harness |
| UNLOCK MOTOR|red/orange | |driver door harness |
| DISARM DEFEAT|pink/orange | |passenger kick panel |
| PARKING LIGHTS +|brown | |headlight switch or GEM *1 |
| HEADLIGHTS|red/yellow |+ |headlight switch |
| DOOR TRIGGER|*2 |- |GEM *1 |
| DOME SUPERVISION|use door trigger | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER|tan/yellow | |instrument cluster or PCM *3|
| SPEED SENSE|gray/black | |GEM *1 |
| BRAKE WIRE|lt. green |+ |brake pedal switch |
| HORN TRIGGER|yellow/lt. green |- |steering column |
| WIPERS|wht (L), blu/org (H)|+ |windshield wiper motor |
| LF WINDOW UP/DN|wht/blk - red |A |driver window motor |
| RF WINDOW UP/DN|wht/yel - tan/lt blu|A |driver door harness or PKP |
| RADIO 12V|lt. green/purple |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/black |+ |radio |
| RADIO ILLUMINATE|lt. blue/red(dimmer)|+ |radio |
| LF SPEAKER|org/lt grn-lt blu/wh| |radio |
| RF SPEAKER|wht/lt grn - grn/org| |radio |
| LR SPEAKER|gry/lt blu - tan/yel| |radio |
| RR SPEAKER|org/red - brn/pnk | |radio |
Username: Tjmutlow
Post Number: 1936
2000 Chevrolet Blazer S-Series Stereo Information
Constant 12V+ Orange
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Rear Speakers 6 1/2" Rear Doors
Left Rear (+) Brown
Right Rear (-) Light Blue
Username: Tjmutlow
Post Number: 1937
1989-92 Mitsubishi Galant Stereo Information
Switched 12V+ Blue
Ground Chassis
Dimmer Black/Yellow
Antenna Left Rear
Front Speakers 3 1/2" Dash
Username: Tjmutlow
Post Number: 1938
Information )
1995-97 Ford Ranger Stereo Information
Constant 12V+ Green/Purple
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Left Front (-) Orange/Light Green
Rear Speakers 5" x 7" Rear Corners
Username: Tjmutlow
Post Number: 1940
1994-96 Ford Escort Stereo Information
Ground Red
Dimmer n/a
Antenna Trigger n/a
Username: Andy812
need help with 1999 ford escort zx2 wire colors. I heard that TY dude kicks bootie at it???!!
I NEED HELP DESPERATELY! 1991 FORD THUNDERBIRD. I need to know what these wires for the radio/speakers does, and where I connect them to.
Red (Very Fat wire)
Black
Blue/Red
Yellow/Black
Green/Pink
Orange/Black
I know these are for the speakers only because they come in bundles of two. But which speaker do they go to?
Bundle 1:
Pink/Light Blue
Pink/Light Green
Bundle 2:
Dark Green/Orange
Light Tan/Light Green
Bundle 3:
Blue/White
Orange/Light Green
Bundle 4:
Pink/Light Blue
Dark Green/Orange
HELP WOULD BE MUCH APRECIATED! THANKS!
Username: Tjmutlow
Post Number: 1946
thunderbird posted above
Username: Tjmutlow
Post Number: 1947
do not see for the zx2, but here is the reg if it will help
1999 Ford Escort Stereo Information
Ground Black
Dimmer n/a
Antenna Trigger n/a
Left Front (+) Purple
Right Front (+) Blue/White
Right Front (-) White
Rear Speakers 6" x 8" Rear Deck
Left Rear (+) White/Blue
Left Rear (-) Red/Blue
Right Rear (+) White/Green
Right Rear (-) Blue
Username: Andy812
99' Escort ZX2
OK I know these are my speaker wires and I checked the rear to see what went were. Which ones are + and -?
Blue/White, Right Rear
Orange, Right Rear
Purple, Left Rear
Pink, Left Rear
The other speaker wires I don't know are
BLUE???
BLACK/WHITE???
BLACK/RED???
RED/BLUE???
My other wires are
Black, Ground
Red/Black, Illumination
Blue/Black, Switched 12V
Blue/Red, Constant 12V
WHITE/ORANGE????
GREEN?????
Username: Bigpappacaine
do you know the wiring harness for a 94 thunderbird?
Username: Mashout
ty, i've been looking for somebody who could help me out and you seem like just the guy I need. I'm looking for a wiring diagram for a 1995 acura legend gs. You think you could help me out??? I'd apprectiate it!!!
Username: Nypdlapd
Post Number: 321
WELL I AM NOT TY, BUT NYPD-LAPD CAN HELP U!!!
95 legend:
Ground Black
Antenna Left Rear
Front Speakers
Rear Speakers
Username: Nypdlapd
Post Number: 324
IF YOU NEED WIRING HELP>>>>>>>>GO TO MY THREAD "anyone need wiring help!!!"
Username: Tjmutlow
Post Number: 1950
1994 Ford Thunderbird Stereo Information
Dimmer n/a
Antenna Right Front
thanks stereo works great )
Username: Bogo
Hi All,
I just put a new JVC KD-DV7025 in my car (Mistusbishi Lancer/Mirage CE 02).
This is the first head unit I have ever had with 'Illunination Control'. Apparently when I turn the lights on the head unit dims.
The manual says nothing about what voltages are tolerable. It simply states connect to 'car light control switch'.
Is it possible to hook this up to the light that powers the lamps in the dash near the ciggarette lighter?
If I run 12v to this cable will I kill my head unit?
- Shane
Username: Mashout
'95 Legend
hey NY, i've found every colored wire except for the constant 12v+ (blue/white) wire...........???? are sure it isn't another color???
Username: Nypdlapd
Scarbz, Ontario Canada
Post Number: 334
Yea thats the wires?? Are u using a wiringharness cuz the wires i gave you were the cars stock wires??
Username: Natesharp
How about the wires for a 1994 Honda accord?
Thanks in advance.
Username: Nypdlapd
Ontario Canada
Post Number: 342
1994 Honda Accord
Ground Black
Front Speakers
Rear Speakers
Username: Nypdlapd
Ontario Canada
Post Number: 343
Sorry left one out*****
Antenna Trigger Yellow/White
Username: Lilbrace23
I need the wiring colors for a 1996 Saturn SL
Username: Nypdlapd
Ontario Canada
Post Number: 354
Ground Black
Illumination Gray
Dimmer Brown
Front Speakers
Left Front (+) Tan
Left Front (-) Gray
Rear Speakers
Left Rear (+) Brown
Username: Morbious
i was wondering if sombody can find me the color cordinations for a factory digital combo w/tape deck no cd changer remote function.
Username: Childoflight
I recently purchased a used Mitsubishi Mirage DE from a used car dealer, and I came to find out a disturbing fact.
the cd deck that is in the center tower in the dash doesn't work(not so disturbing), upon further inspection, the deck was not connected at all to the wires inside!(disturbing! :-O )
well, whatever the case, the I wasn't planning on using the deck anyways :P
I need to get my pioneer deck from my old toyata tercel into my 2000 mitsubishi mirage, but whoever ripped the deck out of this mirage didn't do so with care, the wires aren't capped or taped closed, and no wiring harness at all. the wires are pretty short too. I see the normal set of 4 power type wires
red yellow black blue
and then there's a group of 8 wires that are presumeably for the speakers
(not sure of the colors right now, I can find out by going back out to my car, a lot of orange or brown colors it seemed, and there were 2 that were connected and taped together. what would be up with that?
so if someone could help me out with telling me the speaker colors that this 2000 mitsubishi mirage should have, that would be most helpful.
Username: Gotitmade17
any one know about 1999 ford ranger radio wiring?? i'm doing an install for my friend and he can't find one anywhere...
Username: Nypdlapd
Ontario Canada
Post Number: 376
1999 Ford Ranger
Constant 12V+ Light Green
Ground Black
Front Speakers
Right Front (+) Dark Green/Orange
Right Front (-) White/Light Green
Rear Speakers
Username: Reese444
Have 96 Saturn Radio/Cassette without harness connector. Which ones are for which speakers? I am putting this in a boat so I would I wouldnt think this would be much of an issue, correct?
2 green
2 brown
2 blue
2 grey
1 orange
1 purple
1 black
1 red
1 yellow
Thanks for any help!
Username: Skies
Courtenay, British Colu... Canada
Post Number: 71
Need wiring diagram for a 05 ranger
Thanks in advance
Username: Nypdlapd
Ontario Canada
Post Number: 385
ranger:
Antenna Right Front
Front Speakers
Rear Speakers
Username: Caliguls
I'm glad I found you guys. I been looking
everywhere for a wiring diagram for a 97
Mirage. Any help would be greatly appreciate
any help you can give me. Many thanks.
Username: Tjmutlow
Post Number: 2010
1997 Mitsubishi Mirage Stereo Information
Switched 12V+ Blue
Ground Chassis
Dimmer Black/Yellow
Username: Edwindiaz
Cumberland, Ri
i need information if anybody can help me please. I need the radio wiring diagram for a 1997 Ford Taurus SHO...
Username: Tjmutlow
Post Number: 2021
1996-97 Ford Taurus Stereo Information
Dimmer n/a
Antenna Left Rear
Username: Scorka88
i need the wiring diagram for a 1999 pontiac grand am, any help would be most appreciated
Username: Tjmutlow
Post Number: 2038
1999 Pontiac Grand Am Stereo Information
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Rear
Front Speakers 4" x 6" Doors
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Username: Scorka88
Thank you, thats a life saver Ty
Username: Crazyeric
Looking for speaker wire color code for a 96 ford explorer with factory amp...no place seemed to have the correct harness to go into the black plug. Thanks
Username: Tjmutlow
Post Number: 2069
you need a ford premium harness, go to a stero shop or crutchfield. there maybe 2, it can have 2 plugs(1 small black speaker plug and a grey) or the other is a (grey and a green), goes for the bigger black plug. need to see picture, go to www.bestkits.com
Username: Character47
I need information if anybody can help me please. I need the radio-wiring diagram for a 1994 full size blazer.
Username: Qslimms
Swanton, Oh Usa
Post Number: 50
heres a odd one how bout the wiring for a 99 mitsubishi diamante
Username: Tjmutlow
Post Number: 2114
I have nothing for the diamante, but this may be the same
1999 Mitsubishi Galant Stereo Information
Switched 12V+ Blue
Ground Chassis
Dimmer n/a
Antenna Rear Window
Username: Tjmutlow
Post Number: 2115
1994 Chevrolet Blazer 4WD Stereo Information
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Rear Speakers 4" x 10" Roof Mount
Left Rear (+) Brown
Username: The_red_cutlass
ty mutlow i was wondering if i can get the radio wiring for a 97 olds cutlass supreme? thanks
Username: Tjmutlow
Post Number: 2124
1995-97 Oldsmobile Cutlass Supreme Stereo Information
Ground Black/White
Illumination Gray/Black
Dimmer Brown/White
Antenna Trigger Dark Green
Antenna Right Rear
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Username: Ntbissonette
i need the wiring diagram for a 1997 ford escort, any help would be appreciated.
Username: Nirom8585
my stereo was stolen from my 93 camry and they cut the factory harness, so ineed the diagram. any help would be appreciated.
Username: X_man
can i get the wiring diagram for a dodge colt
Username: Tjmutlow
Post Number: 2141
1997 Ford Escort Stereo Information
Ground Black
Dimmer n/a
Antenna Trigger n/a
Right Rear (-) Blue
Username: Tjmutlow
Post Number: 2142
1992-93 Toyota Camry Stereo Information
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer Black/Gray
Left Front (+) Pink
Left Rear (+) Black
Right Rear (+) Red
Username: Tjmutlow
Post Number: 2143
dodge colt, no years sooo.
1994 Dodge Colt Stereo Information
Switched 12V+ Blue/White
Ground Chassis
Illumination n/a
Dimmer Red/Black
Left Front (+) Blue
Left Front (-) Blue/White
Right Front (+) Blue/Red
Right Front (-) Blue/Yellow
Left Rear (+) Blue/White
Left Rear (-) Blue/Green
Right Rear (+) Blue/Red
Right Rear (-) Blue/Green
Username: Cproctor88
I need a wiring diagram for a 91 ford explorer am/fm stock stereo please
Username: Jeffs_s10
I need a wiring diagram for a 1997 Chevrolet S-10 pickup truck. 4.3L, manual trans. please
Username: Tjmutlow
Post Number: 2188
1990-91 Ford Explorer Stereo Information
Ground Black
Dimmer n/a
Antenna Right Front
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (-) Brown/Yellow
Right Rear (-) Black/White
Username: Tjmutlow
Post Number: 2189
1995-97 Chevrolet S-10 Pickup Stereo Information
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Rear Speakers 6 1/2" Front Doors
Left Rear (+) Brown
Username: Insainebunny
I have a 98 mitsubishi eclipse, what does the dimmer/ground wire on the radio harness go to?
Username: Tjmutlow
Post Number: 2219
to the black and yellow wire
Switched 12V+ Blue
Ground Chassis
Dimmer Black/Yellow
Antenna Left Rear
Username: Helene34
hello,
I want to install some rear speakers in my Toyota Tercel 95. There are currently no speakers intalled in the rear (only in the front).
My problem is that I don't know to which wires I have to connect my speakers. Can someone help me out so that I can locate them ?
Thanks !
Username: Tjmutlow
Post Number: 2231
1995-96 Toyota Tercel Stereo Information
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Left Front (+) Pink
Left Rear (+) Black
Right Rear (+) Red
Username: Jocon
Could you please help me with the wiring for a
1989 Ford LTD
Username: Rej
Hey yy! This is brilliant information :-)
Wondering if you can give me the wiring for a "1998 Mitsubishi Mirage"
Thanks heaps :-)
Username: Rej
Hey ty! This is brilliant information :-)
Thanks heaps :-)
