whats really the smallest mdf someone should use to make a box. I already started with 3/4 but i need to make dividers amongst the subs and i don't think 3/4 will fit. thanks for your help!
Also wanted to install a small plexiglass window in my box. Routed a small ledge to sit it on but is there some foam that i could buy so it doesn't rattle. Where would i get it? THanks
try ur hardest to fit it...but if u cant use 1/2...which i dont reccomend bu ttht is the next smallest size i believe....and just screw the plexi ad put clear liquid nails to glue it....it shouldnt rattled....
