Wiring Kits
Username: Aman2005
Post Number: 118
Every one saying I need amp I need subs.
I need WIRING KIT
PLease read it all before posting your comments.
I have a hifonics brutus 1000D amp with two type R subs SWR 1042D. I am thinking to setuo it at my own. I need a wiring kit for that. I want to fit the amp in trunk. Please tell me which gauge wire will be best suted for that??
I think the distance from battery and trunk will be bwtween 10 feets, sure not to be more than that stated length.
Username: Splmonster
Post Number: 155
id use 4ga
Username: Nemen
Post Number: 862
i would go with 2 gauge but 4 gauge should work....
Username: Stnorris
Eldridge, IA US
Post Number: 243
id go with 4 gauge. it will work perfect.
Username: Thomas_g
NM
Post Number: 1190
Here, heres a chart u can go through........:
http://www.the12volt.com/info/recwirsz.asp
